Does This Need To Be Addressed??? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-24-2013, 01:05 PM   #1
Rewards Points: 874
Does this need to be addressed???
Before I insulate and Sheetrock should something be done about this crack? I'm sure it's been there for a looong time. Never had any water issues etc. thanks
Mstrlucky74 is offline   Reply With Quote
Old 11-24-2013, 01:12 PM   #2
Rewards Points: 13,266
I would seal it with epoxy crack sealer.
http://www.radonseal.com/crack-injec...ack-filler.htm
Mstrlucky74 (11-24-2013)
Old 11-24-2013, 01:13 PM   #3
Rewards Points: 216
what is on the outside ?
Fix'n it is offline   Reply With Quote
Old 11-24-2013, 01:52 PM   #4
joed's Avatar
Rewards Points: 11,988
You need to fix the wiring as well.
The cables need to be fasten within 8 inches of the box.
The cable need to be supported either by going through the studs or being stapled every 4 feet.
The Following User Says Thank You to joed For This Useful Post:
Old 11-24-2013, 01:56 PM   #5
Rewards Points: 874
Just siding ......
Old 11-24-2013, 05:38 PM   #6
Rewards Points: 502
That could well be normal cmu shrinkage.
But it looks a little wider at the top than the bottom - that can sometimes be an indication of settlement. But if it's been there a long time and assuming it was settlement, it's probably stopped by now.
If it's giving no trouble, just fill and forget.
tony.g is offline   Reply With Quote
The Following User Says Thank You to tony.g For This Useful Post:
Old 11-24-2013, 07:03 PM   #7
It needs to be filled so cold airs not coming in the crack and hitting the warm air on the back side of the drywall. Sure way to have mold.
Old 11-24-2013, 08:10 PM   #8
Rewards Points: 216
Originally Posted by Mstrlucky74 View Post
Just siding ......
so your saying that is all above grade ?
do what has been said.
Old 11-25-2013, 08:00 PM   #9
Rewards Points: 874
so your saying that is all above grade ? do what has been said.
Yes it is... Thanks
foundation repair jblackburn Building & Construction 3 04-01-2011 07:28 PM
