Does My New Home Have Structural Issues? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-07-2012, 07:23 PM   #1
Does my new home have structural issues?
First of all HI! Never thought I would be in a DUI forum but I was about to buy a house until I checked out the basement and saw these support beams.. First of all why do they look so cheap, are they hiding something, and I noticed they were cranked at different heights... Is this normal, or should I run for the hills?
Thanks in advance!
thefonz222 is offline   Reply With Quote
Old 02-07-2012, 07:27 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Everything looks good to me.
What cracks?
titanoman is offline   Reply With Quote
The Following User Says Thank You to titanoman For This Useful Post:
gregzoll (02-20-2012)
Old 02-07-2012, 07:31 PM   #3
Just concerned about the support beams. I know nothing about construction but are they standard? Why is one raised higher than the other... Do you think this indicates an uneven floor plan??
Old 02-07-2012, 07:32 PM   #4
What cracks?
Cranked not cracked.
Old 02-07-2012, 07:36 PM   #5
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,334
these types of posts are adjustable. they get turned to changed the height which will make a beam level. the reason they are at different heights is probably do to the strip footings being at slightly different elevations, this is nothing unusual and nothing to worry about
where its a steel beam the plates on the posts have clearly been welded to the beam so they dont move. perfectly fine. if it were a wood beam either conventional lumber or engineerd there would be a laminated 2x6 post of a 6x6 post cut to fit where the beam would be level
you should be all good.. the only thing that should be addresses is why the exterior walls aren't drywalled. locally its a requirement to get a occupancy permit. either drywall hasnt started yet or it was ommitted in the basement.
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
thefonz222 (02-07-2012)
Old 02-07-2012, 07:38 PM   #6
Appreciate the feedback. I can rest a little easier.
Old 02-07-2012, 07:41 PM   #7
DIY staff
Rewards Points: 7,174
That drywall is a local code thing---would not be a problem here---
Old 02-07-2012, 07:52 PM   #8
Learning Things Every Day
Jay 78's Avatar
DUI forums are no good. The 'traffic' is too erratic.
Under Construction
Jay 78 is offline   Reply With Quote
The Following 2 Users Say Thank You to Jay 78 For This Useful Post:
gregzoll (02-20-2012), Julius793 (02-08-2012)
Old 02-07-2012, 07:53 PM   #9
I wish my house sat on big steel beams like that lol. Looks buff
conspikuous is offline   Reply With Quote
Old 02-07-2012, 07:57 PM   #10
Wink
Had to read this twice.. HILARIOUS!!!
Jilligoat is offline   Reply With Quote
The Following User Says Thank You to Jilligoat For This Useful Post:
woodworkbykirk (02-08-2012)
Old 02-07-2012, 07:57 PM   #11
Beat me too it, DUI. Drunk driving
Hardway is offline   Reply With Quote
Old 02-07-2012, 08:00 PM   #12
KemoSabe
loneframer's Avatar
Those screw jacks would fail in my area. The adjustable portion has to be buried in concrete to render them permanently set with no adjustment possible.
It's not that it took him an hour to make 100 bucks, it's that it didn't take you 10 hours to save 100 bucks.
loneframer is offline   Reply With Quote
The Following User Says Thank You to loneframer For This Useful Post:
oh'mike (02-08-2012)
Old 02-07-2012, 08:14 PM   #13
Rewards Points: 14,306
If your looking to buy this house then you need to hire your own home inspector not just guessing and asking questions on the net to people that have never set foot on the property.
Best money you ever spent if he does his job right. Gives you a heads up on what wrong before you buy.
1910NE (02-21-2012)
Old 02-07-2012, 08:25 PM   #14
Inspection is in 2 days time. I just can't wait that long.. I need to know now if it's even worth getting an inspector if the situation is really bad or not.. Just sending out the feelers.
Old 02-07-2012, 08:53 PM   #15
Civil Engineer
Rewards Points: 4,942
The average inspector is not going to be able to tell you if those posts meet code, because that is a detailed structural issue way beyond what an inspector is going to look at. They may be fine, but the only way to know for sure if they meet code is to contact the manufacturer to verify that the specific post (they are called lally columns by the way) is rated for permanent use with the screw jack extended. Surprisingly, a lot of lally columns with screw jacks are actually intended for temporary support. Many "temporary rated" lally columns have been in permanent use for years, often with no problem, but they typically do not meet code. Maybe not an issue to you, but at least worth checking out.
Daniel Holzman is online now   Reply With Quote
Tags
support beam
Need home plans for a simple barn home! RUMBLON General DIY Discussions 0 06-02-2011 03:05 PM
Home Sprinkler Issues mer1971 Landscaping & Lawn Care 2 04-27-2009 08:18 AM
Older home -- Open Ground issues, please help Toyz Electrical 1 06-15-2008 08:41 AM
A facelift for your home Grumpy Remodeling 0 07-07-2004 07:43 PM
