Does Felt Paper Allow A House To Breathe? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-07-2009, 08:35 PM   #1
Rewards Points: 260
Does felt paper allow a house to breathe?
Does felt paper allow a house to breathe? I'm concerned about moisture passing through the interior walls and getting trapped in the framing. My main concern is mold growth behind the drywall and backerboard in a bathroom. The felt is attached directly to the wall studs because of the type of siding.
bluefitness is offline   Reply With Quote
Old 02-07-2009, 09:17 PM   #2
Registered User
Termite's Avatar
In my opinion, yes. Felt is lapped just like lap siding, but certainly isn't airtight. Felt has been around for probably a century and is still used in some capacity on basically every home built today. However, if you're worried about making the wall really breathe, go with Tyvek instead.
Old 02-08-2009, 08:42 AM   #3
Remodeling Contractor
Both will allow it to breath. Tyvek allows it to breathe more. Most experts list #15 asphalt felt as having a permeance of 4 or 5 perms. The permeance of housewraps varies from brand to brand; Tuff Weather Wrap has a permeance of 6 perms, Barricade has a permeance of 9 perms, and Tyvek has a permeance of 58 perms. Of course, the ability of asphalt felt or housewrap to resist liquid water penetration is a whole other issue; one can't assume that low permeance wraps resist liquid water better than high permeance wraps.
Connecting main house to guest house... hlavine Building & Construction 31 03-28-2012 09:04 AM
replumbing an old house simonfrog Plumbing 7 01-30-2012 04:45 AM
Using Felt with Cedar Shakes freddmc Roofing/Siding 32 10-08-2011 11:26 AM
Grounding for two service entrances to same house. jogr Electrical 18 09-24-2008 10:31 AM
Is felt paper a sufficient vapor barrier for hardwood floor? jaj808 Flooring 15 03-27-2008 10:57 PM
