Do You Two Half Studs Make A Full Stud? - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-15-2013, 11:42 AM   #16
Framing Contractor
Originally Posted by hankbeasley View Post
I called the inspector. He confirmed the only way to do this is with full length studs. Thanks.
There ya go....you have your answer. Now hire a REAL contractor with a license and insurance to fix the problem after the sheetrock is taken out and AFTER a licensed electricians takes out the wires .
Then the REAL contractor can put the studs in and an electrician can drill holes in the studs to put the wires back in.
Does this so called contractor have a license and insurance ?
Joe Carola
Joe Carola is offline   Reply With Quote
Old 02-15-2013, 03:48 PM   #17
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,214
im with joe caption on this one.. if its no longer a bearing wall.what should have been done is a sil plate put on top of the cut off studs. then the purple studs could be nailed down to that and then the top plate
by lapping them with only a 6" splice the joint can pivot.. theres no strength there
woodworkbykirk is offline   Reply With Quote
Tags
load bearing wall , studs
moving a load bearing stud Tonglebeak Building & Construction 34 07-07-2010 12:32 PM
Stud finder not picking up ceiling studs Delta223 General DIY Discussions 9 03-26-2010 07:52 PM
Basement half walls to full walls Basement Man Remodeling 11 03-29-2009 02:33 PM
using 8' studs vs 7'-9" studs RINAIL Carpentry 2 07-10-2008 04:16 PM
Jack Studs Clutchcargo Building & Construction 7 09-06-2007 06:10 AM
