Do You Two Half Studs Make A Full Stud? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-14-2013, 10:42 PM   #1
Do you two half studs make a full stud?
I have a contractor doing some remodeling work for me. He removed the top half of a load bearing wall to make a raised bar. Then the plans changed and we needed to put the wall back. Look at how he put the studs back.
You can't see it from the picture but the new purple studs do not go to the ground. The new studs overlap the old cut off studs by about 6 six inches and then they are nailed together. I do not know very much about carpentry but this seems very wrong to me. If it is wrong how wrong is it? And is there any safe way to replace only the half of the stud that was cut off without replacing the full studs? A way that would pass building code?
Do you two half studs make a full stud?-2013-02-14_21-28-51_570.jpg   Do you two half studs make a full stud?-2013-02-14_21-29-23_436.jpg   Do you two half studs make a full stud?-2013-02-14_21-28-43_466.jpg
hankbeasley is offline   Reply With Quote
Old 02-14-2013, 10:47 PM   #2
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 692
If the former load bearing wall was cut out, was the load carried in some other way? If so, I don't think these would not need to support anything, and are just there to hold drywall - a partition wall.
hyunelan2 is offline   Reply With Quote
Old 02-14-2013, 10:51 PM   #3
There was plans for a support beam but it was never put in. So no, the load is not carried another way. Above these studs is two 2x4's stacked and perpendicular joist.
Old 02-14-2013, 11:08 PM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 2,124
If that bent over nail is any indication of work quality....I'd be concerned.
Wood is cheap....if load bearing, the studs need to go all the way to the floor. That 6" lap will have almost no strength.
Old 02-14-2013, 11:19 PM   #5
There are some wires running through the bottom have of the studs. When I tell him this is not going to work he may try put another cut off stud directly on top of the cut off ones with a some kind of bracket. Its that ok or do I need to make him replace all studs with full length studs?
Old 02-15-2013, 12:29 AM   #6
What you have described is NOT acceptable. If the plans changes were your decision, you need to pay him to do the job correctly. The building inspector will not sign off on this "repair".
gogetter is offline   Reply With Quote
Old 02-15-2013, 01:21 AM   #7
Rewards Points: 626
Whoa! I would be very upset that is not going to fly. why was a load bearing wall cut in the first place? who's brilliant idea was that? and how was the load supported? and what he did will not work period! also whats up with mauve studs?
Nailbags is offline   Reply With Quote
Old 02-15-2013, 07:02 AM   #8
Rewards Points: 14,306
He should have installed 2 X 4's laying flat at the top and bottom the filled in the rest of the area with what amounts to cripple studs that sit over the old studs. No differant then filling in an old window or door opening.
woodworkbykirk (02-15-2013)
Old 02-15-2013, 07:32 AM   #9
What you are describing sounds reasonable and safe. Do you think it will pass inspection? I have tried searching through building code. I cannot find any related material.
Old 02-15-2013, 08:22 AM   #10
I called the inspector. He confirmed the only way to do this is with full length studs. Thanks.
Old 02-15-2013, 08:24 AM   #11
joed's Avatar
Rewards Points: 13,738
If that wall is load bearing then that is not acceptable. The load is being carried by whatever fastener he used between the two studs.
At the very least the pink studs should have been set on top of the cut studs and a new piece sistered across the joint. This way the load is transfer straight down. And I am not even sure that is suitable. I am not an engineer.
Old 02-15-2013, 08:30 AM   #12
kwikfishron's Avatar
Rewards Points: 1,006
Originally Posted by hankbeasley View Post
I have a contractor
No you don't!
I think it's time for you to step back and reevaluate your choice on who's working on your house.
Anyone that would even attempt what you're showing in the pictures has no clue of what there doing.
Scary stuff.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
Old 02-15-2013, 08:32 AM   #13
Yeah, that was part of question too. It seems obviously wrong to me.
Old 02-15-2013, 09:20 AM   #14
Gymschu's Avatar
Rewards Points: 1,024
Some of those studs look awfully out of plumb.
Gymschu is online now   Reply With Quote
Old 02-15-2013, 11:14 AM   #15
Rewards Points: 3,130
What's with the purple studs?? Where are you located??
Tags
load bearing wall , studs
moving a load bearing stud Tonglebeak Building & Construction 34 07-07-2010 12:32 PM
Stud finder not picking up ceiling studs Delta223 General DIY Discussions 9 03-26-2010 07:52 PM
Basement half walls to full walls Basement Man Remodeling 11 03-29-2009 02:33 PM
using 8' studs vs 7'-9" studs RINAIL Carpentry 2 07-10-2008 04:16 PM
Jack Studs Clutchcargo Building & Construction 7 09-06-2007 06:10 AM
