Do You Need To Insulate Behind Soffit? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-29-2007, 03:56 PM   #1
yummy mummy's Avatar
Rewards Points: 1,016
Do you need to insulate behind soffit?
I am building a soffit that is against a wall that I will be insulating.
Do I bring the insulation all the way up from the bottom to the top plate or do I stop it where the soffit begins?
If I do, is it ok for the insulation to be near the ductwork when it will be enclosed? (Fire hazard?)
Thanks.
yummy mummy is offline   Reply With Quote
Old 03-29-2007, 06:49 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Thanks.
I would suggest that you just insulate the entire wall itself.
That will provide your heating envelope or conditioned space.
Then the soffit is simply some wood in front of the insulated wall and it does not require insulation.
...And, yes, you can insulate right up to ductwork...
- Build Well -
Old 03-29-2007, 07:59 PM   #3
atlantic
Just so I have this straight.
If I insulate and put vapor barrier on the entire wall, then the heating duct will be close to the vapor barrier, and that's ok?
Old 03-29-2007, 08:26 PM   #4
Yep. That heating duct is not going to heat up to any point of danger...It's just pushing out warm air....
- Build Well -
Old 03-29-2007, 08:41 PM   #5
Atlantic
Thank you atlantic.
You are a darling................
(Now if you can just give beer geek some lessons).
Just kidding beer geek. Don't get the panties in a knot.
I love you too......
Old 03-29-2007, 10:11 PM   #6
Rewards Points: 150
There's something seriously wrong with you. Obsess much?
It takes less time to do a thing right than it does to explain why you did it wrong.
-Henry Wadsworth Longfellow
beer_geek is offline   Reply With Quote
Old 03-30-2007, 12:56 PM   #7
She said she loves you.
steel is offline   Reply With Quote
Old 04-10-2007, 10:54 PM   #8
ADKstorm's Avatar
Thanks.
Depending on your local building codes, you might need fire blocking in the wall at the soffit.
ADKstorm is offline   Reply With Quote
Another Ridge Vent, Gable vent and soffit question (??) davco Roofing/Siding 2 05-01-2007 12:14 AM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 08:46 AM
Installing Soffit and Facia??? Vikeologist Roofing/Siding 3 11-15-2006 06:01 PM
Removing ductwork in soffit... inovermyhead HVAC 2 04-02-2006 11:56 PM
Soffit installation question milano Roofing/Siding 4 02-04-2006 11:13 PM
