-   -   Do you need to insulate behind soffit? (http://www.diychatroom.com/f19/do-you-need-insulate-behind-soffit-7444/)
yummy mummy 03-29-2007 02:56 PM
I am building a soffit that is against a wall that I will be insulating.
Do I bring the insulation all the way up from the bottom to the top plate or do I stop it where the soffit begins?
If I do, is it ok for the insulation to be near the ductwork when it will be enclosed? (Fire hazard?)
Thanks.
AtlanticWBConst. 03-29-2007 05:49 PM
Thanks.
I would suggest that you just insulate the entire wall itself.
That will provide your heating envelope or conditioned space.
Then the soffit is simply some wood in front of the insulated wall and it does not require insulation.
...And, yes, you can insulate right up to ductwork...
yummy mummy 03-29-2007 06:59 PM
atlantic
Just so I have this straight.
If I insulate and put vapor barrier on the entire wall, then the heating duct will be close to the vapor barrier, and that's ok?
AtlanticWBConst. 03-29-2007 07:26 PM
Yep. That heating duct is not going to heat up to any point of danger...It's just pushing out warm air....
yummy mummy 03-29-2007 07:41 PM
Atlantic
Thank you atlantic.
You are a darling................:wink:
(Now if you can just give beer geek some lessons).
Just kidding beer geek. Don't get the panties in a knot.
I love you too......
beer_geek 03-29-2007 09:11 PM
There's something seriously wrong with you. Obsess much?
steel 03-30-2007 11:56 AM
She said she loves you.
ADKstorm 04-10-2007 09:54 PM
Thanks.
Depending on your local building codes, you might need fire blocking in the wall at the soffit.
http://img340.imageshack.us/img340/2268/soffitgr8.jpg
