Do I Need Subfloor? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-20-2011, 10:56 PM   #1
do i need subfloor?
not sure where to post this!
building a timber frame stair..the upper landing is complete..see photos
my question is this:
I am planning on putting 2x8 tongue and groove on the landing...I want the tongue and groove to be seen from below..like the loft..loft has sub floor built up to allow for cam lights into the living room
the landing is 60" wide, 58" long 53 1/2" tall...built from 6x8 doug fir. middle post is 21 1/2" on west side and 23" on east..due to the construction of the timber frame home.
Can I get away with just laying the 2x8 t&g directly on the landing?
Do I have to use a subfloor? (3/4" plywood)
chulett is offline   Reply With Quote
Old 02-20-2011, 11:41 PM   #2
Residential Designer
AndyGump's Avatar
Rewards Points: 664
Send a message via Skype™ to AndyGump
I think no plywood is needed, you will be able to allow elephants to sit on that without any deflection.
Andy.
AndyGump is offline   Reply With Quote
Old 02-20-2011, 11:57 PM   #3
lol..sounds good! gonna start putting stingers and treads together next week..stringers are 4x12s and treads are 4x10s..i think stairs should last...only concern is lifting em into place!
will post more photos as project goes ahead
another crazy question:
I am going to use 1/2 rebar...4 of em welded together for the spindles..not sure this is forum to ask, but how do you get them clean? cant find anything online expect for electrolysis! Good old elbow grease with angle iron and steel wool the best method?
Gonna put em between doug fir 4x4
Would you replace this subfloor? winterminute Flooring 2 11-30-2010 11:48 AM
Need guidance on subfloor problems in new home. wb1026 Flooring 9 10-06-2009 07:29 AM
Replacing Subfloor whatispunk Flooring 1 09-01-2009 10:50 PM
Subfloor Help, Please! OmahaGirl Flooring 1 01-26-2009 09:06 AM
Subfloor / underlayment question... scheenstra Flooring 7 02-21-2008 08:39 AM
