Do I Need A Sill Pan For An Entry Door That Sits On Brick Vs. Wood? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-14-2010, 03:54 PM   #1
Rewards Points: 45
Do I need a sill pan for an entry door that sits on brick vs. wood?
I have to replace my 36" entry door on the back of my garage and as I look at the original, I can see that it is sitting on bricks that are flush with the concrete slab of the garage floor. With this setup is there a need to install a sill pan since the interior side of the water dam will be exposed to traffic in the garage since there is no finished floor to but up against?
kooshball is offline   Reply With Quote
Old 12-14-2010, 04:11 PM   #2
If you get the measurements spot on, the back side of the pan will but up against the back side of sill of your door. Just make sure you (i dont know the terminology I just know how my guy does it) return the metal on itself so the top of the metal edge is not sharp.
Everything I state on this forum is an opinion I have developed based on my experience and research as a professional.
wnabcptrNH is offline   Reply With Quote
replacing rotten sill plate on brick exterior home S.LaRue Remodeling 11 11-02-2011 08:50 PM
Door Sill Flashing Pondo13 Building & Construction 1 08-19-2009 06:15 AM
Should I seal where wood trim meets the brick? megan81 Building & Construction 1 07-01-2008 12:40 PM
Brick and wood flooring jhughesfam Flooring 1 08-18-2007 03:29 PM
PORCH - from BRICK to WOOD Kukurigu Building & Construction 1 11-12-2005 09:33 PM
