Do I Need Screening Under Attic Vents? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-07-2013, 01:31 PM   #1
Rewards Points: 99
Do I need screening under attic vents?
Short ques. Had two turbine attic vents installed to boost inadequate venting from earlier contractor. Do I need to tack up some screening under the vent holes to prevent insects intruding? Nothing mentioned in any of the installation manuals about such a step.
Thanks.
Hossenfeffer is offline   Reply With Quote
Old 05-07-2013, 04:40 PM   #2
Old School
Willie T's Avatar
No more than you should have screens on your windows and doors.
Willie T
Old 05-07-2013, 06:56 PM   #3
Renovating My Land Yacht
Rewards Points: 616
Thanks for bringing this up. I recently changed one out and rewired two others and putting screen up and screening the holes never even entered into my head. Living in the mosquito capital of the northern hemisphere you would think that would be one of the first things to think of.
Robyn
forcedreno2012 is offline   Reply With Quote
Old 05-07-2013, 10:38 PM   #4
Architectural Sculptor
RWolff's Avatar
Rewards Points: 502
Screening will keep out insects and bugs as well as bats, birds, squirrels, and rats and mice, and yes, rats and mice can climb quite well.
Just don't forget to keep the screens clean of leaves and buildup of dust and dirt, cobwebs etc
RWolff is offline   Reply With Quote
Old 05-08-2013, 01:06 AM   #5
Registered User
Rewards Points: 526
http://publicecodes.cyberregs.com/ic...9_8_sec006.htm
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
forcedreno2012 (05-08-2013)
Attic (cross)ventilation - pre-insulation Qs Izaura Insulation 9 02-28-2013 10:57 PM
Attic project - Would like opinions whataboutj Insulation 6 06-29-2011 03:07 PM
Attic baffles but no overhang or soffit vents. Ptron Roofing/Siding 12 08-04-2010 10:51 AM
Installing Soffit vents w/finished attic Nathan0115 Roofing/Siding 6 06-04-2010 09:05 PM
How to keep attic pipes from freezing in winter with gable vents ErikKratz HVAC 7 07-11-2008 09:32 PM
