Do I Need To Replace My Lally Columns? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-23-2009, 08:23 AM   #1
Do I need to replace my Lally columns?
Hi,
I have four Lally columns in my 50-year-old garage that are pretty rusted. Two of them have sections on the bottom that are rusted fully through to the concrete underneath the metal. The worst parts of the rust are within 6" of the ground.
The layout is a regular-sized 2-car garage, and the first Lally columns is in the front between the 2 garage doors, and the other 3 are between the cars. The back of the garage has a full wall. The Lally columns are supporting a large beam that has no wall on the floor above. Above the garage are 2 bedrooms.
I've had 2 contractors insist that we need to replace the lally columns immediately because it isn't safe, and I've had 2 contractors tell me that it isn't a big deal and that I shouldn't worry about it. I've researched on the Web but I've found nothing conclusive. We originally brought in the contractors to look at replacing the garage floor, which is horribly pocked and rough due, apparently, to a previous owner's love of salt in the winter. The garage floors get moist after a day of rain or so and, after a week of solid rain, there may be a couple of small areas collecting <.25" of water. The garage is on the uphill side of the house (we're on a hill).
All that said, any opinions? Do we need to replace our Lally columns? Can someone explain why, in either case?
Thank you very much!
Best regards...
charbroiled is offline   Reply With Quote
Old 09-23-2009, 08:33 AM   #2
joed's Avatar
Rewards Points: 11,598
If the steel is rusted through to the concrete then you need to replace them.
Old 09-23-2009, 06:14 PM   #3
Rewards Points: 4,454
' lally column ' was a proprietary name of conc filled pipes invent'd by john lally,,, his cousin was harry lally - harry wasted his time & was never noted for doing anything other'n being the inspiration for lally-gaggers therefore john is the better known of the 2 cousins john's are conc fill'd to add fire resistance so the columns don't collapse when temps rise due to possible fire,,, harry's, hot air
on a lighter note, if the steel's rusted away, there is no solid support,,, any supporting column should be located on its own proper steel reinforc'd foundation.
contractors who encourage replacement are more pro than the others however they may not be aware of conc resurfacing w/polymer-modified cements which may be a viable cost-alternative for your fine garage floor,,, send joe a pm & ask him !
Old 09-23-2009, 08:43 PM   #4
Billy
Send a message via AIM to willcmjr
I would replace them with perminent lally columns. Not the telescoping ones you can pick up at any hardware store, but single piece columns with just one end with a screw jack. (Most codes don't allow for the telescoping ones for perminent use). You'll have to measure the height and buy the right size. You can order these at Lowes. In some cases, these are actually cheaper than the heavy duty telescoping ones, and have a higher weight limit.
They should be mounted perminently. The way I do it is attach a piece of pressure treated lumber to the floor (there are many ways to do this), then bolt the column to that. It should be bolted on the top as well. I'm sure it goes without saying they have to be perfectly plumb.
Put the adjustable end on the bottom. There are multiple reasons for this, but you'll be much less likely to hurt yourself by pulling a muscle adjusting it down at floor level than reaching over your head or standing on a ladder.
http://www.octoberhome.com/articles/...ustcolumn.html
The first type on this page is the type I'm referring to.
Hope this helps.
Billy
willcmjr is offline   Reply With Quote
Old 09-24-2009, 07:28 AM   #5
Thank you for the replies... I'm not sure if these extra facts are relevant, but the existing columns are permanent columns mounted below the floor, presumably into the footer. They certainly continue to "feel" solidly in place even though parts of the metal has rusted completely through. As far as I can tell, the concrete beneath the metal looks fine and fully in tact.
I'm actually trying to get in touch with someone at a column company to get their thoughts as well. I had another contractor last night take a look and insist we didn't need to replace them.
If the columns are well-mounted below the floor, does this make a difference despite the rust? Also, I don't see screws in the top of the column - it looks like they are either pressure fit to the beam or go into the beam. The paint on the column and ceiling make it difficult to tell.
thanks!
Old 09-24-2009, 09:29 AM   #6
Billy
There's no mistaking the "screw", if you can't see it, it's not there. They make them in fixed length, and can be put in at the time the foundation/footers are pored. The height has to be exact.
If they are rusted through then you have lost some of the structural integrity of the post. A column loses that if it's not continuous. They may be still sufficient. But nothing short of a structural engineer will be able to tell you that for a fact. Any contractors you have come out are just speculating like us on here.
My firm advice: structural engineer or replace them.
Interior Column's larrylwill Remodeling 4 07-26-2009 03:05 PM
replacing front porch columns rayrgdx General DIY Discussions 4 07-23-2008 06:08 AM
Removing lally columns tbone128 Carpentry 3 11-14-2007 10:02 AM
Replacing a concrete tube lally Bob2468 Building & Construction 5 05-08-2007 09:27 AM
