Old 10-14-2009, 02:19 PM   #1
Question Do I need a New Construction or Replacement Window?
I believe this would normally be an easy question to answer. However, I am replacing a set of "Fake" french doors (double doors, one fixed, one opens) with a window.
We have vinyl siding on the exterior, and I'll have to build the bottom of the frame to make the wall where the bottom of the door used to be. This is a set of doors on the second floor going onto an attached deck (we already have two and don't need 4 doors on a 30 foot deck!).
So I'm going to remove the doors & door jambs, and work with that rough opening size (width only, obviously).
Other than getting a more exact size, is there any reason to pick one over the other? Is one more likely to come with an integrated J-Channel for the vinyl siding, and would I need a sill - or is that personal choice?
Any help would be greatly appreciated. We are in a hurry, since the deck wasn't flashed (I'm flashing it as I re-hang the existing doors and replace the rotted wood & threasholds) and there is water intrusion into the basement. Any more and the large beams down there will get damaged.
Thanks anyone!
bmack500 is offline   Reply With Quote
Old 10-14-2009, 03:01 PM   #2
Use a new Construction window.
Old 10-14-2009, 03:03 PM   #3
General Contractor
ARI001 is offline   Reply With Quote
Tags
door, jambs, replacement, window
More On This Topic
Watch conclusion for refinishing a door jamb in this free house remodeling video from an expert finish carpenter and experienced home inspector. Read More »
Learn how to paint refinished door jamb in this free house remodeling video from an expert finish carpenter and experienced home inspector. Read More »
Learn tools needed to refinish a door jamb in this free house remodeling video from an expert finish carpenter and experienced home inspector. Read More »
Learn how to caulk when refinishing door jamb in this free house remodeling video from an expert finish carpenter and experienced home inspector. Read More »
Learn about applying second primer coat to refinish a door jamb in this free house remodeling video from an expert finish carpenter and experienced home inspector. Read More »
Reusing a new construction window qoncept Building & Construction 3 09-17-2009 05:10 PM
Replacement Window with nailing fin mjbcable Building & Construction 0 09-15-2009 03:40 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 07:11 PM
latest problem...window replacement gone_fishing Remodeling 10 02-11-2008 10:24 AM
Replacement window as new construction mt232 Building & Construction 2 03-23-2007 01:18 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
