Do I Need To Get Tempered Windows? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-24-2012, 03:01 PM   #1
Rewards Points: 37
Do I need to get tempered windows?
I'm re-doing this house to sell, this window is near a door. The old one was not tempered, but I don't want any issues with the home inspector when I sell.
And these two full length windows are on each side of the 80" sliding door..
aminus21 is offline   Reply With Quote
Old 07-24-2012, 03:07 PM   #2
Yes, all 3 should have been tempered.
CopperClad is offline   Reply With Quote
Old 07-24-2012, 03:09 PM   #3
Rewards Points: 37
Do home inspectors make a big deal of this during the sale? I'm almost done with this house (painting today)..
Do you advise ripping out the windows and filling up the wall, or ordering tempered glass?
Old 07-24-2012, 03:14 PM   #4
Rewards Points: 37
This is the house remodel..
1960s South Bay House Remodel
Old 07-24-2012, 03:22 PM   #5
Yes they will make a big deal about it. Because you are in California anytime you pull the frames of the old windows you have to pull a permit. And any time you add a new window you have to pull a permit. And any time you pull permits they look for things such as tempered glass. So.. You're answer from me is yes you should replace with the proper glass. Maybe someone else will have a different suggestion but I doubt it...
Old 07-24-2012, 03:41 PM   #6
Generally speaking the window does not require to be tempered unless the window is replaced and it is 24 inches from the door jamb. So is the window original? Was it replaced in the past when you were living in the home? If you answered yes to having it replaced by you or you intend to have it replaced prior to the sale and it is within 24 inches from the jamb then tempered glass is required. If the window is not within 24-inches from the jamb but you are in a specific fire zone location, then the local authority for permitting may require one of 2 panes (double pane window) to be tempered. You have to check with your local building permit center. If the window is within 18 inches of the door jamb and you intend on replacing the window then you have to have dual tempered glass.
Shuriko is offline   Reply With Quote
Old 07-24-2012, 05:31 PM   #7
Rewards Points: 37
Both of the single hung windows next to the 32" door have been replaced with dual-pane Milguard windows.
Old 07-24-2012, 07:25 PM   #8
JOATMON
ddawg16's Avatar
Rewards Points: 1,116
The tempered glass will also need a label on it to say it's tempered. It's usually sand blasted in during the tempering process.
ddawg16 is online now   Reply With Quote
Old 07-24-2012, 11:07 PM   #9
It just occured to me you wrote home inspector. You are refering to the buyer's inspector or building inspector? Buyer's inspector may note that the window is non-tempered (if required) but the purchaser may be willing to waive the requirement.
Does the City/building department require a certificate of occupancy? If so this is where you are more than likely to get nab.
I did not see the picture of the windows next to the sliding glass. Those, if new or replaced by you, require double pane tempered glass. The size, location, and the fact it is less than 18-inches off the floor triggers the requirement.
Old 07-25-2012, 10:12 AM   #10
Residential Designer
AndyGump's Avatar
Rewards Points: 662
Send a message via Skype™ to AndyGump
Here is part of the CRC 2010 as regards the windows.
R308.4 Hazardous locations. The following shall be considered specific hazardous locations for the purposes of glazing:
1. Glazing in all fixed and operable panels of swinging, sliding and bifold doors.
Exceptions: 1. Glazed openings of a size through which a 3-inch diameter (76 mm) sphere is unable to pass. 2. Decorative glazing. 2. Glazing in an individual fixed or operable panel adjacent to a door where the nearest vertical edge is within a 24-inch (610 mm) arc of the door in a closed position and whose bottom edge is less than 60 inches (1524 mm) above the floor or walking surface.
Looks like in needs to be tempered in your situation.
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
The Following 2 Users Say Thank You to AndyGump For This Useful Post:
GBrackins (07-25-2012), mae-ling (07-25-2012)
Old 07-26-2012, 01:09 PM   #11
Rewards Points: 37
I'm referring to buyer's inspector. Thanks for the info everyone.
Replace just two windows - dumb idea? ChrisJJ Windows and Doors 13 06-01-2012 11:31 AM
Any restitution for VERY late windows? msbriggs Building & Construction 21 10-05-2010 07:25 AM
Windows XP Mode in Windows 7! poppameth PC Repairs & Upgrades 5 04-28-2009 01:18 PM
How do I install new windows? RickT Carpentry 17 10-12-2006 07:06 PM
