Do I Need Gap Between Wall And Underlayment? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-29-2013, 02:40 PM   #1
Do i need gap between wall and underlayment?
I normally leave a small gap between the wall and plywood underlayment assuming it would expand and contract. My worker forgot to do that in one of the rooms. Will this be a problem. I assume it won't be a problem since it's being nailed down. But I don't know for sure. Here's a picture:
jclee is offline   Reply With Quote
Old 04-29-2013, 02:57 PM   #2
Roofmaster
Rewards Points: 2,210
If this is in a conditioned space I would not worry about it at all. It is a real concern on a roof where a delta T of 100 degrees is not unusual, but indoors I would not even worry about it. Why isnt the wall on top of the underlayment, remodel?
Old 04-29-2013, 03:39 PM   #3
Yes. It is a Remodel. This is an 3/8 underlayment on top of a 1/2 floor sheathing (I think that's the correct term)
Can you insulate timber frame wall cavity with brick fascad? nowwhatnapster Insulation 5 03-13-2013 08:25 AM
New tub w/flange - tile surround & underlayment ques. spidrw Kitchen & Bath Remodeling 8 07-21-2010 11:29 AM
Subfloor and Underlayment Thickness and Materials Joe_NJ Flooring 0 06-07-2010 05:39 PM
Wall Prep for new bath tub Randell Tarin Building & Construction 6 03-25-2008 11:26 PM
laminate floor underlayment installation? KUIPORNG Flooring 1 03-08-2007 05:52 PM
