Do I Need A Footing For 3' X 10" Bump Out In The Southwest.? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-07-2010, 10:43 PM   #1
Comet
Do I need a footing for 3' X 10" bump out in the southwest.?
I would like to build a 3 X 10 foot bump out. I have concrete slab and will attach to for the bump out. Do I need to add a footing?
Joe
jgonza62 is offline   Reply With Quote
Old 10-07-2010, 11:00 PM   #2
Rewards Points: 1,910
If you don't it's likely that the roof/wall weight will crack the slab and/or the slap perimeter will sink and if the ground freezes in your area the heaving could cause problems.
The Following User Says Thank You to jogr For This Useful Post:
jgonza62 (10-09-2010)
Old 10-08-2010, 05:50 AM   #3
Rewards Points: 4,800
if your soil's capable of supporting the weight, no,,, you can dig a trench & fill it w/crushed ston,,, many old adobe structures are blt the same way - on adobe
The Following User Says Thank You to stadry For This Useful Post:
Old 10-08-2010, 04:04 PM   #4
Framing Contractor
Joe
Call your building inspector and ask him/her.
Joe Carola
Joe Carola is offline   Reply With Quote
The Following User Says Thank You to Joe Carola For This Useful Post:
Old 10-08-2010, 05:26 PM   #5
Registered User
Rewards Points: 526
While you are there (B.D.), ask them what size replacement beam you need to remove the studs in your way.....
and posts, footings, shear panels to make the wall structurally sound again, shear continuity strapping connections, plastic required under the now heated slab area, foundation to old foundation re-bar needed, etc.
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
Old 10-09-2010, 11:27 AM   #6
correct answer, although I don't know why you couldn't just dig some holes every 6' and pour concrete supports.
mrgins is offline   Reply With Quote
Deck Framing - Beams on top of footing (not enough space for post) Maatoy Building & Construction 18 06-02-2010 08:03 PM
Footing drains in crawlspace on top of footing jbitt Building & Construction 8 01-12-2010 01:50 PM
Sinking footing tubes Farmer Z Building & Construction 19 11-17-2009 08:50 AM
footing drain question chrisk Building & Construction 2 09-02-2007 07:21 PM
Wrong Footing Dimensions HELP jhernan35 Building & Construction 2 04-15-2007 02:22 PM
