-   -   Do I need a footing for 3' X 10" bump out in the southwest.? (http://www.diychatroom.com/f19/do-i-need-footing-3-x-10-quot-bump-out-southwest-83341/)
jgonza62 10-07-2010 10:43 PM
I would like to build a 3 X 10 foot bump out. I have concrete slab and will attach to for the bump out. Do I need to add a footing?
Joe
jogr 10-07-2010 11:00 PM
If you don't it's likely that the roof/wall weight will crack the slab and/or the slap perimeter will sink and if the ground freezes in your area the heaving could cause problems.
stadry 10-08-2010 05:50 AM
if your soil's capable of supporting the weight, no,,, you can dig a trench & fill it w/crushed ston,,, many old adobe structures are blt the same way - on adobe
Joe Carola 10-08-2010 04:04 PM
Joe
Call your building inspector and ask him/her.
Gary in WA 10-08-2010 05:26 PM
While you are there (B.D.), ask them what size replacement beam you need to remove the studs in your way.....
and posts, footings, shear panels to make the wall structurally sound again, shear continuity strapping connections, plastic required under the now heated slab area, foundation to old foundation re-bar needed, etc.
Gary
mrgins 10-09-2010 11:27 AM
correct answer, although I don't know why you couldn't just dig some holes every 6' and pour concrete supports.
