Do I Need A Drip Cap In This Situation? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-03-2010, 11:56 AM   #1
Rewards Points: 508
Do I Need a Drip Cap in This Situation?
I'm putting in flanged windows in a wall sheathed with Huber's Zip System (OSB with integrated WRB). Should I use just butyl tape over the top flange, or should I sandwich a drip cap between two pieces of butyl tape?
On a different note, I think I'm going to tear out the bottom sill. Should I replace it with a ripped down 2x4 ripped at a -10 bevel? I'm using FlexWrap as a sill pan.
benjamincall is offline   Reply With Quote
Old 06-04-2010, 10:25 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
i would do the metal drip cap,you can just add a ripped down pcs of wood siding for your angle pitching to the outside
Tom Struble is offline   Reply With Quote
Old 06-04-2010, 11:22 PM   #3
Rewards Points: 508
Thanks, Tom. I ended up ripping a 1x4 I had lying around. I'll go with a metal drip cap. Should I go over the trim with the cap? I didn't have them on any of the windows already installed in the house, so I can't use them as a reference. Do you typically paint them to match casing or the jamb?
Old 06-05-2010, 05:52 AM   #4
over the trim,but there are situations where i will install one directly over the unit and then one over the trim, and they usually are color matched to the trim
Best way to waterproof fascia when roof lacks a drip edge? Studly Roofing/Siding 4 10-07-2009 10:49 AM
need advice pinning down existing drip cap balaway General DIY Discussions 2 05-07-2009 05:15 PM
drip cap question marlinpuppy Building & Construction 1 03-17-2009 11:10 PM
Window is 4" narrower than RO, and Drip Cap ? yung-cheng Building & Construction 2 08-07-2008 08:14 PM
Shingle Installation with F5S Standard Drip Edge ShortEdged Roofing/Siding 32 02-15-2008 02:10 PM
