Old 10-26-2012, 11:27 AM   #1
do I have to use cripple studs
We are building a garage door header in the opening to or daylight basement. THe way the wall is I'm only gonna have a 6' opening in the garge door with a 5' cripple stud. The house is gonna be 2 story with an attic. so it will end up being a load bearing wall so is it possible to just make the 2x12 header and attach it the top base plate without using cripple studs or do you have to use a cripple stud?
ashby316 is offline   Reply With Quote
Old 10-26-2012, 12:12 PM   #2
Civil Engineer
There is no code requirement that I am aware of to use cripple studs if they are not needed. I put in two headers in my house, both are steel beams, neither has any cripple studs as the headers are tight against the existing wood double top plate. Or maybe I misunderstood your question?
In any case, you should check with local code official if a door less than 6 feet tall is acceptable, it certainly would not be where I live. Also, how did you size your header as a 2x12? Are you certain it is adequate?
The Following 2 Users Say Thank You to Daniel Holzman For This Useful Post:
ashby316 (10-26-2012), mae-ling (10-26-2012)
Old 10-26-2012, 07:33 PM   #3
Question
I'm Sorry I meant that I am using a 2x 11 1/4 header. The rough opening to the door is 6 ft with 5 inch cripple stud. So if my wooden headers are 2x11 1/4 do I still have to use a cripple stud if i put it flush with the double top plate. even though its load bearing cause if i don't then i will be able to have a bigger door. I'm not to keen on wanting a 6ft rough opening for a garage door.
Old 10-26-2012, 07:48 PM   #4
GBrackins's Avatar
a 6-foot high garage door?????
do you have any photos?
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is online now   Reply With Quote
Old 10-27-2012, 07:29 PM   #5
A 6' tall garage door? that is unusual, but the question is must you use cripple studs above the header and below the plate. The answer is no, and I have often oversized the header or packed a 2 X 4 or two above, and below, the header to avoid the use of cripples as I believe it makes for a better structure.
TheCamper is offline   Reply With Quote
Wood or Steel wall studs? dredogol Building & Construction 2 07-10-2011 08:31 AM
Making wall studs plumb and on plane laxgrandma Carpentry 1 07-06-2011 06:32 PM
Attaching a worksurface directly to studs in of a basement wall BasementVirgin Building & Construction 3 10-06-2010 01:04 PM
New foundation for bathroom floor and exterior wall studs JayG Building & Construction 2 07-11-2010 02:25 PM
Cripple studs below a header mercy Building & Construction 3 01-20-2010 04:20 PM
