Do I Have To Put A Nail In Every Hole On Corner Bead... - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-24-2008, 07:53 PM   #1
yummy mummy's Avatar
Rewards Points: 1,016
Do I have to put a nail in every hole on corner bead...
I noticed that on one side the holes are 12 inches apart and on the other side they are 6 inches apart.
Do I have to put a nail in every hole?
(Silly question, I know)
yummy mummy is offline   Reply With Quote
Old 03-24-2008, 08:25 PM   #2
No. Every foot on each side is fine.
jerryh3 is offline   Reply With Quote
Old 03-24-2008, 08:39 PM   #3
BuilderRemodeler
cornerbead
Keeping the cornerbead fastened securely where it begins and ends is important to prevent future cracking. (Use the very top holes if the cornerbead is vertical)
12" O.C. is fine unless the cornerbead is flexing or there is a gap yet.
BuilderRemodeler
40 pages of useful Home Remodeling Charts, Home Addition Guidelines, Home Painting Tips, How to Determine a Deck Size and Build Your Deck Online! www.BrandsConstruction.com
www.HomePlansForFree.com One Story Ranch Detailed Free Home Plans
darylbrands is offline   Reply With Quote
Old 03-24-2008, 08:54 PM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Everyone knows...it's three nails per hole...
- Build Well -
Old 03-24-2008, 08:55 PM   #5
- Build Well -
Old 03-24-2008, 11:00 PM   #6
CozumelDiver's Avatar
Cut drywall rarely ends up in nice square corners before applying the corner bead. One trick I like to use is putting a fair amount of drywall compound on the INSIDE of the corner bead before sticking it to the wall (amount depends on the size of the gap). Press it to the corner very firmly and it will "stick" there. You may get some compound oozing out the nail holes, this is fine, just wipe it off when finished. This will give you a more solid corner (less prone to "dents" and deters any very tiny critters that might get under the baseboard from nesting in the gaps between the drywall edges. This works particularly well with the "rounded" corner beads which I personally prefer.
As the others have mentioned, 1 nail per foot or so on each side works well... (I like to stagger" them from side to side, so you actually end up with a nail in the corner bead about every six inches or so...)
CozumelDiver is offline   Reply With Quote
Old 03-24-2008, 11:43 PM   #7
Thanks very much.
One nail every 12 inches sounds good to me.
Atlantic, you're funny.....
Old 03-25-2008, 12:36 AM   #8
I blame ProWallGuy
Rewards Points: 150
Thanks very much.
He gets paid by the nail.
Double A is offline   Reply With Quote
Old 03-25-2008, 08:39 AM   #9
Probably very well.
corner bead on existing wall stallinc Building & Construction 12 01-30-2008 07:38 AM
How to mitre bullnose corner bead?? Arbs Building & Construction 3 01-28-2008 12:32 PM
Drywall corner bead Question dk_99 Building & Construction 5 01-01-2008 03:25 PM
Mounting corner Bead KUIPORNG Remodeling 7 01-04-2007 08:20 AM
