Do I Have To Build To Code? - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-15-2013, 10:22 PM   #16
Rewards Points: 3,130
Originally Posted by Daugela View Post
The code for basement egress is a ladder from a window well. I didn't build the house but assume the ladder attached to this "oversized" window well was suffice. Why wouldn't it be? This is essentially a window well but the previous owner went one step further and put in a door.
"Why wouldn't it be?" What size is the window? How high above the ground is the bottom of the window opening? How wide is the door opening? Here, these things would determine if the setup satisfies egress requirements. The dimensions of the well may also come into play. Don't know about that or ladder requirements since I don't have a basement.
Old 12-16-2013, 08:58 AM   #17
GBrackins's Avatar
Rewards Points: 2,108
That's interesting. With this info, I wonder if the stairs could comply with the above ladder/rung dimensions. If the steps ARE NOT REQUIRED to comply with the R311.5-.6, then what are they to comply with?
in my area ladders are ladders and stairs must comply with the minimum tread depth and maximum riser height. the two cannot be mixed.
as many others have said, ask the building official.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 12-16-2013, 09:59 AM   #18
Concrete & Masonry
Rewards Points: 620
The inspector could always say my well is so big, it's not considered a window well and therefore would need to comply with 311.5. I guess I need to ask. I would hate to build it, invest the money to only find out it would pass inspection.
Most egress window wells I've installed have stepped/terraced panels in the back for egress, typically 16-18" tall (riser) and 4-6" deep (tread). They're perfectly legal for egress. As other's have stated though, check with your local inspection dept. first........
jomama45 is online now   Reply With Quote
Old 12-16-2013, 11:43 AM   #19
cortell's Avatar
Rewards Points: 504
Seems clear-cut to me. That is without a doubt a window well (granted, larger than most). IRC says steps in window wells are excluded from the width requirements of standard stairways. So, your concern of being 1" short of code is unwarranted, since that code requirement does not apply in this situation. Note that the window well exception does not apply to tread and riser requirements, as GBrackins has basically pointed out. Those requirements are safety-critical--not meeting them would create a significant tripping hazard.
That said, like politics, code is mostly local. There is a possibility more restrictive codes apply to your area. But at least from a national code perspective, it seems clear to me you're in the clear (pun intended).
cortell is offline   Reply With Quote
The Following 2 Users Say Thank You to cortell For This Useful Post:
concretemasonry (12-16-2013), Daugela (12-16-2013)
Lighting proximity to outdoor hot tub - Code Question jeffinpickering Electrical 0 09-12-2011 01:43 PM
Bryant Plus 90 Code 31 ~kirkland~ HVAC 1 03-08-2011 06:14 PM
error code 45 Turtle learner HVAC 2 01-10-2011 04:09 PM
Carrier Furnace help code 31 fauxjaux HVAC 6 04-22-2010 10:36 PM
Distance between Heater & Combustibles DIY_JC Building & Construction 7 01-20-2009 07:52 AM
