Do Deck Stairs Require Support Posts? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-14-2012, 12:45 PM   #1
Do deck stairs require support posts?
We are adding stairs to our deck (approx. 9' from the ground) with a turn at 32 in., making the first run 72 in. We are using 4 stringers to ensure support for this first run (our steps are 42 in. wide), but are wondering if it is also suggested to add support posts on the sides (we will have four on our base at the turn)?
krdickson is offline   Reply With Quote
Old 07-14-2012, 01:26 PM   #2
Civil Engineer
Rewards Points: 4,940
You should review the code for your particular location. Where I live, we use International Residential Code 2006, many jurisdictions use the 2009 edition. The IRC code has two pages devoted to proper construction of staircases, with diagrams and discussion. Talk to your building inspector, they should be able to tell you which code you need to adhere to. If you have no building inspector, or do not need to meet code, I would suggest following IRC 2009, you can't go too far wrong if you follow it.
Daniel Holzman is online now   Reply With Quote
Adding support for new hot tub on an existing deck. hammerandnail Building & Construction 8 07-04-2012 06:55 PM
add support posts to existing deck hendan Building & Construction 2 05-14-2012 08:41 AM
Pergola over existing deck cpfullback Building & Construction 0 08-04-2011 11:36 AM
Hanging deck stairs on a cantilever drtbk4ever Building & Construction 11 07-14-2009 08:13 AM
8' x 12' deck how - many support posts needed shuanrit Landscaping & Lawn Care 5 07-09-2009 09:57 PM
