Old 03-17-2010, 04:37 PM   #1
DIY spray foam kits
Originally Posted by NE78FJ40 View Post
When you say "spray foam" are you talking about the kind of spray foam you spray in and it expands to competely fill in the area? Is this something I could buy at a home improvement center? If so, what do I need to ask for?
If I go the rigid board way, once I place the rigid against the outer surfaces on the inside of the rim joist, do I still need to install batt insulation to fill the rest of the area? Some of my rim joist areas are about 2 feet deep. Do I put the rigid board on the outer vertical and lower horizontal areas? Like creating an L shape inside the area.
Sorry to bump an old thread but was wondering where some of the best places to get DIY spray foam kits. HD and Lowes do not seem to carry much past the spray can.
So far I have found a few on eBay and http://www.energyefficientsolutions....amproducts.asp. I am looking to do a 340 sqft master bedroom over a garage.
HitLines is offline   Reply With Quote
Old 03-17-2010, 04:39 PM   #2
DIY spray foam kits
I would Google the company Foam It Green, I think they have good prices and shipping..it also doesn't hurt to look on Ebay. Some of the bigger kits can be put away for a little while until another project, just in case you need to end up buying a larger amount.
mferguson0414 is offline   Reply With Quote
Old 03-17-2010, 05:53 PM   #3
DIY spray foam kits
Here is what I came up with so far. Both products appear to be solid but price might be the winning factor here.
http://www.energyefficientsolutions.com/
FOAM605 - Spray Foam Kit - Quick Set, Two component Polyurethane (1.75 lb/cf), 605 BDFT yield
$590 + 90 shipping = $680
http://www.sprayfoamdirect.com/
FOAM IT 602 DIY Polyurethane Spray Foam Kit
$607.99 + $97.99 = $705.98
Old 03-17-2010, 08:49 PM   #4
Remodeling Contractor
DIY spray foam kits
foam is foam... no difference between your two choices check with local resources. Many states will give tax incentives for this work. Home Star should go through this year but work can not be down by DIYer.. must be done by BP'i building professional auditors. Credits up to $8000 will be avialable towards air sealing and insulation work.
Old 03-18-2010, 01:58 AM   #5
DIY spray foam kits
DIY can use the American recovery and investment act .
Cost of product only , 30% credit on taxes $1500 max total for years 09 and 10.
Has to have a certificate to qualify , here's for the 605.
http://www.energyefficientsolutions....s/FomoCert.pdf
http://www.energyefficientsolutions.com/taxcredit.asp
High Gear is offline   Reply With Quote
Spray foam insulation troyce1 Building & Construction 9 05-24-2011 07:57 PM
Diy spray foam insualtion kits ?? What have I done Building & Construction 3 12-14-2009 09:20 AM
Closed Cell Spray Foam insulation and hiring a contractor. Spud Building & Construction 2 10-14-2009 10:03 AM
spray foam - headers and flat ceiling biglumber35 Building & Construction 2 05-02-2009 12:40 AM
Spray Foam/ Foam Board Hybrid? entropyracer Roofing 2 09-19-2008 08:12 PM
