DIY Spray Foam Insulation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-10-2008, 08:38 AM   #1
DIY Spray foam insulation
anyone used Handi Foam style spray foam in a basement or crawl space?? It is much cheaper than having it done professionally, and would simplify insulationg greatly in my basement.
y2khardtop is offline   Reply With Quote
Old 01-11-2008, 02:47 PM   #2
What areas will you be insulating?
redline is offline   Reply With Quote
Old 01-12-2008, 11:39 AM   #3
directly against a poured concrete basement wall. Since the climate here is mild, it would only be a 1/2" thick or so. The only quote I've gotten from a professional installer was extremely cost prohibitive.
Old 01-12-2008, 06:43 PM   #4
You will not get the same results with the handy foam as you will with the pro spray however depending on the situation this might not matter. If you need the foam to act as a moisture barrier the 1 3/4 lb. handy foam may not qualify while a 2 lb. rigid foam will. Generally the cannister foams work ok for more confined shots but I would prefer the big gun for an open wall. It will also be kinda tough to maintain a 1/2 inch depth too. I think, (may be wrong) that the 80 lb. cannister sets are supposed to do about 400 sq. ft. one inch thick.
scrapiron is offline   Reply With Quote
Pipe insulation: Foam, Rubber, Other? IckesTheSane Plumbing 40 03-21-2016 06:57 PM
Spray foam insulating joists in basement? peethree Building & Construction 13 11-28-2010 08:54 AM
Spray foam simonb Building & Construction 6 11-30-2007 07:11 AM
Spray in foam insulation leted_82 Building & Construction 3 05-31-2007 10:14 AM
