Old 12-13-2009, 02:34 PM   #1
Diy spray foam insualtion kits ??
Has anyone on here used spray foam insulation kits to insulate walls while they are under construction or opened up?
I am redoing an old farmhouse and want to get it as airtight as possible using spray foam in rooms that are getting stripped down to the studs.
I work on things at my own pace and it is pretty sporadic and hard to schedule contractors around my schedule so I like to do everything myself.
Anyone have pointers or suppliers for DIY spray foam kits?
What have I done is offline   Reply With Quote
Old 12-13-2009, 04:44 PM   #2
You can order two part systems online. The Tiger-Foam and Handi-foam seem to run around $1 a board foot in the 600 bf kits. If you're looking for larger quantities the fastkick gun systems can get down to .50 a board foot for the larger kits. Just use google or ebay to search for the kits.
jerryh3 is offline   Reply With Quote
Old 12-14-2009, 07:44 AM   #3
sdsester's Avatar
I would use a pro. The equipment for this heats the materials, has digital controls to control flow and proportions, and mixes finally at the head. It is beyond most DIYers. If you are patient, you can usually get an insulator out to do small jobs on the tail end of something else bigger in the neighborhood. The DIY stuff gets really expensive fast too.
What about something other than foam?
sdsester is offline   Reply With Quote
Old 12-14-2009, 09:20 AM   #4
the Musigician
DangerMouse's Avatar
i've been razoring out sheet foam for my bays and where i screw up a little, i use GS Foam to fill in larger gaps, or caulk for smaller ones. when i finish the walls inside, i'll add 6" fiberglass batt.
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Spray foam insulation troyce1 Building & Construction 9 05-24-2011 07:57 PM
spray foam insulation mikeybobo Building & Construction 11 06-19-2010 05:04 PM
Closed Cell Spray Foam insulation and hiring a contractor. Spud Building & Construction 2 10-14-2009 10:03 AM
spray foam - headers and flat ceiling biglumber35 Building & Construction 2 05-02-2009 12:40 AM
Spray Foam/ Foam Board Hybrid? entropyracer Roofing 2 09-19-2008 08:12 PM
