DIY Rookie: Can I Move This Stud? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-16-2012, 01:13 PM   #1
DIY rookie: Can I move this stud?
Hi all, first time poster and a DIY noob here. I've been thinking about building an AV cabinet that would be housed underneath my existing staircase landing. After doing some preliminary inspection, I found a stud that would need to be moved to accomodate the design. Would appreciate any insight on the following:
1. This stud doesn't appear to be load bearing to me. Perhaps it's there for lateral support?
2. Is this as easy as installing another header and two jack studs on either side of my proposed AV cabinet?
Here is a picture from inside the stairs with the stud in question outlined in red. The second picture is of the stairs with the proposed cabinet design and the same stud overlayed with really bad photoshop. The cabinet would go in the middle square.
Thanks in advance.
DIY rookie: Can I move this stud?-img_0292b.jpg   DIY rookie: Can I move this stud?-img_0287b.jpg
frzamilan is offline   Reply With Quote
Old 07-16-2012, 01:17 PM   #2
Rewards Points: 14,312
Looks like that stud was just to help support the dry wall. It's not really supporting anything else.
Old 07-16-2012, 01:32 PM   #3
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Agreed with Joe
edit.... the OP said adding another header (to three 2x4's) plus adding two jack studs on either side of new a/v cabinet. But then that would mean the two new studs would have to go all the way to the floor
Disclaimer
& Stay Safe
.....Bob Lavery
Old 07-16-2012, 02:20 PM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 2,128
If you remove that stud the stairs will fall and the stud police will be all over you house.........
Yea....like joe said....it's your typical 16" OC studd to support the drywall...it looks like you have a ridge joist/header above that top plate to support the stair platform.
Old 07-16-2012, 02:55 PM   #5
Thank you all.
How many holes can I drill into a wood stud? lostintyme Building & Construction 8 02-28-2012 07:26 PM
When to replace rotted stud vs. epoxy ken57 Building & Construction 4 11-08-2011 06:48 AM
Toggle bolt through stud? djgrant Carpentry 16 09-25-2011 06:41 PM
Steel Stud Device Box Installation tjames Electrical 3 09-15-2011 11:30 AM
Need to move stud in finished partition wall juengl4 Building & Construction 7 02-18-2011 08:36 AM
