DIY 2 Part Spray Foam Insulation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-10-2011, 02:41 PM   #1
DIY 2 Part Spray foam Insulation
I recently saw a show, I think it was a DIY show, where the home builder was doing their own spray in two part foam insulation. It said they rented the equipment from a builder supply store and bought the liquids. I am looking to do this, as I feel I can get a more accurate application as there are specific areas I want to deal with. I called Lowes and HD and neither have it. Is this not a common DIY? Where can I get the equipment?
kphares is offline   Reply With Quote
Old 01-10-2011, 02:53 PM   #2
Experienced
Jackofall1's Avatar
Don't know where you are located but here is one for ya
http://www.masterpkg.com/spray-foam-...ent-rental.htm
conflicting spray foam insulation warnings yogi Building & Construction 8 10-01-2009 10:24 PM
"effective" R-value for spray foam insulation? red86yota Building & Construction 1 04-23-2009 12:18 PM
Advice on closed cell/open cell spray in insulation 794613 Building & Construction 2 10-31-2008 07:56 AM
Spray Foam/ Foam Board Hybrid? entropyracer Roofing/Siding 2 09-19-2008 07:12 PM
DIY Spray foam insulation y2khardtop Building & Construction 3 01-12-2008 06:43 PM
