Dividing Or Packing In Insulaton Batts...which Would Work Best? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-12-2010, 10:29 PM   #1
Rewards Points: 93
Dividing or packing in insulaton batts...which would work best?
Ok, so I it have realized it is far better for me to add a layer of studs over an existing uninsulated drywall and then vapor barrier it warm side to create the proper wall for my office in the unheated garage (this is because the exisiting wall is 12' high and I am only going 8' up with the office wall.
My question:
The new layer of studs will be oriented "flat" on this wall. That is, the inner wall depth will be only 1 and a half inches rather than 3 and a half normally in a stud wall (because of the base ledge of concrete foundation on which they will sit accommodates this orientation best and will give a better seal on the drywall to cold floor edge.)
I know it is counterproductive to flatten (compact) the normal batts (which are normal 12 R fibreglass) down to the thinner wall dimension. But would I achieve a good result by getting 20 R batts and using only half the thickness? Surely this would be better than using only half the thickness of the 12 R batts, no?
Thanks for any tips.
Hossenfeffer is offline   Reply With Quote
Old 04-12-2010, 10:41 PM   #2
For a 1.5" space you need rigid foam for insulation
Once you compress the fiberglass into 1.5" you won't have much Rvalue
Old 04-13-2010, 07:47 AM   #3
Remodeling Contractor
HUH? why studs? and definitely no batt insulation. It is only designed to work as intended. It cannot be compressed and only 1 1/2" would do no good at all. Just glue rigid foam on the wall then drywall and you are done.
Old 04-13-2010, 09:40 AM   #4
Rewards Points: 93
That was my first choice....but it is so expensive.......$20+ per sheet
............that's over $160 for a small wall! Good thing I have just one wall of that dimension.
Old 04-13-2010, 09:42 AM   #5
Why do anything until you can do what will work? Do you think it will be cheaper to do something that offers no gain or that may need to be replaced in a few years?
Old 04-13-2010, 09:52 AM   #6
Pay now for the proper insulation
Or pay more long term in higher heating & AC
Plus probably putting up with a cool draft from a poorly insulated wall
Sometimes you just have to bite the bullet & buy the rigid
...or frame out a normal 2x4 wall & use reg insulation
Figure out which will work better & go from there
Old 04-13-2010, 11:20 AM   #7
Rewards Points: 93
Hey Hey, ease up there!
All I posted was a question to confirm my belief that packing batt insulation was not good....and if "halving" a double R value insulation batt would result in the same as a full thickness R12 insulation.
I never did get an answer to that.....just a lashing about starting a job without wanting to pay for the proper procedure. I never suggested that.
But if I was determined to bull ahead with a stupid idea I would not have begun asking questions in the forum.
Old 04-13-2010, 12:01 PM   #8
Yes, compressing batt insulation decreases its R value.
As for "halving" R20, that's still not going to work.
R value of batt insulation is a function of it's "designed" thickness. That's why R12 is designed for 2x4 (3.5" thick) and R19 is for 2x6 (5.5" thick). So if you bought R19 and halved it, you would need a 2.75" deep cavity to get an R value of about R9. Stated another way, it's just a "bad" to stuff R12 into a 1.5" pocket as it is to stuff 1/2" R19 into a 1.5" pocket.
HooKooDooKu is offline   Reply With Quote
Old 04-13-2010, 01:06 PM   #9
There is fiberglass that is slightly more compressed for a higher RValue
R15 in a 3.5 wall = R4.3 per inch x 1.5" = R6.4...clac might not be 100% accurate
OK...checked a compression chart I have & R13 compressed into a 1.5" space gives you R6.6
R30C & R38C are also slightly more compact for cathedral ceilings
But in 1.5" fiberglass simply does not have enough rvalue
It needs the full stud depth for its stated Rvalue
I put R30 insulation into a 2x6 wall & ended up with R22 as a result
Cutting R20 in 1/2 would give you the equiv of R10
Putting that into a 1.5" wall would give you ~R5.2
So...you are back to rigid or spray foam
Rigid you can DIY, spray foam...not as easily
handling unsafe work by an electrician wuxingming57 Electrical 1 11-14-2009 08:07 PM
Duct work in garage. flashme18 HVAC 1 11-08-2009 07:29 PM
Where are the "Carpenters" ???? wrldruler Carpentry 14 09-11-2008 08:37 AM
HVAC contractor ripoff! sekntonone HVAC 8 04-05-2008 08:15 AM
DIYers and Professionals Can Work Together. WilbUild Building & Construction 5 04-08-2007 02:43 PM
