Divided Wall Doesnt Fit Steel Stud Spacing ? - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-26-2012, 05:58 PM   #16
Question
Seems like a good idea Scottktmrider.I need to use heavier gauge for shelves pictures etc.. The walls I'm planning would be about 12ft tall. Could cross bracing also work with the stud spacing including the odd numbered bay mentioned earlier?
Searcher330 is offline   Reply With Quote
Old 08-27-2012, 03:04 PM   #17
Rewards Points: 454
I dont think you can get 25 gauge that are 12' in length.You will have to go to drywall supply house to get 12' footers.I think lowes all you can get is 8' metal studs.
scottktmrider is offline   Reply With Quote
Old 08-27-2012, 09:53 PM   #18
Question
Thanks it looks like it will be the custom shop. When I install the false plaster ceiling would I frame the drywall wall to the deck?
Tags
framing , steel , stud , wall
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
Stud wall return on a preformed shower base latelifebiker General DIY Discussions 5 11-30-2011 03:56 PM
Moving a Stud HooKooDooKu Building & Construction 5 02-23-2010 01:11 AM
Removing spine wall beko Building & Construction 12 02-02-2010 01:15 AM
Interior Wall Stud Joist Connection Issues. Brandnewruins Carpentry 5 04-22-2009 11:46 PM
