Distribution Of Load Over 3 Supports. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-11-2012, 10:58 PM   #1
Retired carpenter
Distribution of load over 3 supports.
Hello!
If a beam is supported at both ends and also at the center, and it carries an evenly distributed load, does the center support take half of the load and the end supports a quarter of the load each?
Thank you!
abracaboom is offline   Reply With Quote
Old 01-11-2012, 11:07 PM   #2
Rewards Points: 2,212
Hmmm I think that should be right. If it is evenly continuously distributed.
mae-ling is offline   Reply With Quote
The Following User Says Thank You to mae-ling For This Useful Post:
woodworkbykirk (01-12-2012)
Old 01-12-2012, 05:57 AM   #3
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Odd question. Why?
Not if your beam is unbroken.
If it is unbroken, the center post is- more or less-just preventing the structure from sagging. The beam itself is carrying much of the load, not the post.
If it is broken in the center, the center is carrying the ends of two beams and the load above.
The bigger the load gets, the lesser the percentage of the weight of the beam and joists only is, so the calculation changes.
It's a calculation best left to an engineer.
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Old 01-12-2012, 04:51 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,202
the amount of weight each point load is carrying depends entirely on teh house.. one half of a house can have more going on structurally than the other half via bathrooms, dormers on the roof which have point loads on them..
woodworkbykirk is offline   Reply With Quote
Old 01-12-2012, 04:54 PM   #5
MarginallyQualified
Rewards Points: 2,464
Originally Posted by abracaboom View Post
If a (edit: JOIST) is supported at both ends and also at the center, and it carries an evenly distributed load, does the center support take half of the load and the end supports a quarter of the load each?
Sorta.The actual engineering can get complicated.
But the principle is why the floor joists in a house will have a beam
supported by lolly columns running down the middle of the basement
Old 01-12-2012, 05:12 PM   #6
Experienced
Jackofall1's Avatar
Hello!
Thank you!
The simple answer to your question is yes assuming the beam is in the center of the joist span and the center of the beam span and the supported structure is of equal load.
Mark
Old 01-12-2012, 05:58 PM   #7
Rewards Points: 1,580
I think Daniel explained how the forces acted on a beam in a post some time ago; went into some detail about where the loads were placed and how they were transferred to the beam and its support(s). Might try searching for it if interested.
bob22 is offline   Reply With Quote
Old 01-12-2012, 07:13 PM   #8
Civil Engineer
Rewards Points: 4,770
Assuming:
1. Continuous, uniform vertical load. No other loads besides vertical load.
2. The beam is in close contact with each post. The post supports act as pins.
3. The posts are uniformly spaced
4. The beam is continuous over the center post
5. The beam is level, and the top of the posts are level.
6. The beam is of constant cross section.
Then the center post carries 5/8 of the total vertical load, and the end posts carry 3/16 of the total vertical load each. If the beam is NOT continuous over the center post, then the vertical load distributes 1/2 to the center post, 1/4 to each outer post.
The mathematical derivation of this result is complex, and cannot be presented on an internet chat forum. For derivation, see any mechanics of materials textbook.
Daniel Holzman is online now   Reply With Quote
The Following 3 Users Say Thank You to Daniel Holzman For This Useful Post:
AndyGump (01-13-2012), bob22 (01-12-2012), mae-ling (01-12-2012)
Old 01-12-2012, 07:18 PM   #9
Disabled wood vet
titanoman's Avatar
Originally Posted by Daniel Holzman
Assuming:
You explained it much more eloquent than I.
Old 01-13-2012, 12:48 AM   #10
Retired carpenter
Thanks for all the answers!
Now, Square D Combo AFCI Breaker Trips Opens w/No Load Side Connections QO120CAFI mysterylectric Electrical 14 10-27-2013 02:51 PM
Want to open up a load bearing wall - I need advice on a header to carry the load graysqwrl Building & Construction 4 07-16-2011 08:16 AM
Finding Load Bearing Walls Dane Hitchins Building & Construction 15 05-14-2011 10:09 AM
framing, expanding wall opening wall - load bearing? nave Remodeling 5 01-23-2008 03:44 PM
Beam Load Ron Building & Construction 5 09-17-2006 06:28 AM
