Old 01-19-2009, 03:12 PM   #1
Default Distance between Heater & Combustibles
I am building some storage areas (shelving etc) in the unfinished area of the basement. What is the typical distance required between HVAC/water heater and combustible material? I realize this varies by where you live, but I am trying to get a general idea. Location is Jefferson County KY (Louisville suburb) if anybody has specifics to that area...
thanks,
Jeff
DIY_JC is offline   Reply With Quote
Old 01-19-2009, 04:51 PM   #2
Look at the paperwork that came with the water heater, heating unit, etc. It will give you all the info you need.
If the paperwork is missing, use the information on the individual units to look it up on the manufacturers web site.
Ron
Ron6519 is online now   Reply With Quote
Old 01-19-2009, 06:22 PM   #3
Ron
ok, I will check... thanks!
Old 01-19-2009, 06:24 PM   #4
I did find this info (for my area) online so far:
http://dhbc.ky.gov/NR/rdonlyres/0B6D...ndPrinting.pdf
Kentucky has adopted state-wide codes that can not be amended locally. • The new 2007 Kentucky Building Code (KBC), ninth edition went into effect July 6, 2007. The ninth edition of the KBC will be the 2006
International Building Code (IBC) and the specific Kentucky amendments (2007 KBC) to the 2006 IBC.
For Kentucky state building codes, click here.
Louisville Kentucky Building Codes
Code Type Code Model Amendment Contact
Building/Dwelling Code 2007 KBC (2006 IBC)
Structural Code 2007 KBC (2006 IBC)
Plumbing Code 2007
Mechanical Code 2007 KBC (2006 IMC, 2006 IFGC)
Electrical Code 2005 NEC - NFPA 70
Fire/Life Safety Code 2007 KBC (2006 IFC)
Accessibility Code 2007 KBC (2003 ICC/ANSI A 117.1)
Energy Code 2007 KBC (2006 IECC)
Elevator Code 2007 KBC
Other Codes Gas Code: 2007 KBC (2006 IFGC)
The 2007 Kentucky Building Code is scheduled to become effective on July 1, 2007. Unlike the current 2002 Kentucky Building Code, the 2007 edition of the KBC is not a stand-alone code book unto itself; it is a compilation of amendments to the 2006 International Building Code. To correctly use the new code, it will be necessary to refer to both the 2006 IBC and the 2007 Kentucky amendments. HBC has also issued an amended Table 1608.2 that should be incorporated to correct an error in this document.
Ky adopted the 2006 IBC with 76 pages of amendments
You can download the amendments free from aia.org but the IBC has to be purchased at iccsafe.or
Old 01-19-2009, 06:28 PM   #5
I also found this reference in the 'FAQ/Common Question' area of my county website. It does not pertain directly... but there may be some correlation..
Question: I would like to install a wood burning stove at my residence. My question: what is the minimum required clearance (from combustibles) of single, double, and triple wall stove pipe
Answer: Single wall 18 inches; Double wall Manufacturers requirements; Triple wall Manufacturers requirements
Old 01-20-2009, 07:34 AM   #6
The manufacturers requirements would be in the paperwork that came with the various units.
Ron
Old 01-20-2009, 07:56 AM   #7
Here are some guidelines provided by NFPA:
Rivethead is offline   Reply With Quote
Old 01-20-2009, 09:52 AM   #8
Building codes guy, Mod
thekctermite's Avatar
Manufacturer requirements are what you should be looking at for specifics. Code is pretty silent, so the inspector will likely ask for the manufacturer's installation paperwork. 30" in front of the access panel of the furnace is the norm, and all parts of the equipment must be reasonably accessible for service and replacement.
thekctermite is offline   Reply With Quote
More On This Topic
I'm Chris Knab for Expert Village. What I've found when I was in retail is that the cover that you make of your CD, your lst one or your 21st one whatever it is, is absolutely crucial to stand out from all your competitors who is making records as well... Read More »
Hi! I’m Stephanie Phillips for expertvillage.com and we’re going to talk about passport requirements. Did you realize that as of December 2006 that will be the last time that you’ll be able to go on a plane to go to Canada or Mexico... Read More »
Now I am going to talk about filing status as a qualifying widow or widower with a dependent child. You can use this filing status which will entitle you to use joint return tax rates in the high standard deduction amount if you don't itemize deductions... Read More »
Using Google Number Ranges
Using Google Number Ranges by Expert Village
Hi, I'm Gary for Expert Village. Let?s see how to use a number range in Google. This could be very helpful when we want to specify either dollar amounts or dates and we are only looking for certain items within a specific number range. So, let?s take a... Read More »
In this clip I am going to show you how to do headlight restoration. On most of the vehicles they get foggy just like this specific car. This is a 96 vehicle but these days we have been having 2006 and 2007's that get fogged up due to condensation from... Read More »
Gas Hot Water Heater Tank and Pressure Relief Valve skadoo323 Plumbing 0 01-12-2009 10:52 PM
Water heater drain mechanism (10 year old) guptaalok Plumbing 1 01-02-2009 07:40 AM
Water heater problem bear1957 Plumbing 23 11-01-2007 05:53 PM
Baseboard heater Help! jweinstock Electrical 6 10-28-2006 06:01 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 12:31 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
