Old 12-29-2008, 03:15 PM   #1
dissipating mortar b/ween bricks
i have a couple of exposed brick walls that i am restoring and, in some spots, the mortar between bricks is getting kind of sandy and dissipating when rubbed. what should i do to get it nice and solid again ? can i rub out whatever i can get off that is falling off and reapply new mortar ? my skepticism is that that wouldn't hold because it would be just on surface, i.e. would not have too much grip and would fall off soon. is there some mortar-like epoxy type solution that would make sure to stay on forever ?
Old 12-29-2008, 03:31 PM   #2
Moderator
Termite's Avatar
You can redo the mortar. Do an internet search for "tuck pointing" and you'll get all the answers you need.
Old 12-29-2008, 03:41 PM   #3
termite, you are my king !
Old 12-30-2008, 09:17 AM   #4
'mite, got a call this am for some tucking,,, seems the guy who tried it 1st used silicone out of a caulk tube our price was too high the 1st time,,, wonder what it'll be this afternoon never even used diamond blades - just smeared stuff over the brick
yesitsconcrete is offline   Reply With Quote
Old 01-02-2009, 04:16 PM   #5
i couldn't find any instruction on WWW how to do it. should i just take out as much of the old mortar as possible using a grinder and a diamond blade and stuff new mortar in ?
Old 01-02-2009, 05:17 PM   #6
you don't mention the age of the house so it might be older lime-enriched mortar which's softer than modern mixes,,, the purpose was flexibility for softer brick,,, modern brick's harder so often enriching w/lime's often deleted.
old brick doesn't take well to grinders & tuck-point blades as you'll lose too much of the brick unless you're REALLY careful,,, we still use hammers & tuckpointing chisels for historical work.
Old 01-02-2009, 05:24 PM   #7
my house is celebrating its 100th b-day this year. here is a picture of the wall, from which i am currently peeling the old paint away. what you can see are peeled test patches, all of the paint will actually be peeled off.
dissipating mortar b/ween bricks-peelaway_2_prcsd.jpg.jpg   dissipating mortar b/ween bricks-peelaway_3_prcsd.jpg.jpg   dissipating mortar b/ween bricks-peelaway_4_prcsd.jpg.jpg
Old 01-02-2009, 06:36 PM   #8
just curious if you're using a citrus or soy paint stripper
Bad Brick Mortar ??? kourso Building & Construction 21 11-08-2010 01:11 AM
Basement Wall Mortar rory535 Building & Construction 16 08-06-2009 10:39 AM
Can I dye existing brick mortar? Foo by Tore General Discussion 2 10-30-2008 08:03 PM
Is it bad to use mortar to level a floor? CB2007 Flooring 4 10-01-2008 09:38 AM
Mortar removal from salvaged brick. Rem8 Building & Construction 8 07-20-2008 08:05 AM
