Dishwasher Anchor Holes Under The Counter Top - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-12-2013, 09:27 PM   #1
Dishwasher Anchor Holes under the Counter top
Thanks in advance for your help. My issue is with my laminate counter top and the dishwasher. The holes under the counter have been stripped so the screws that anchor it, won't go back in the holes. The holes are too wide. What I can put in there that will harden up so I can drill screws back in it again, and keep my dishwasher from tipping forward every time I open the door? I really don't want to replace the counter top if I don't have to.
Thanks.....Tim
tnhuskerfan is offline   Reply With Quote
Old 03-12-2013, 09:38 PM   #2
DIY staff
Rewards Points: 7,174
Clean out any loose saw dust ---mix a small batch of epoxy with some saw dust---pack the hole --insert the screw into the wet epoxy--clamp until set---
JB Weld could be used----
Wood glue mixed with saw dust---then drilled and screwed
lots of choices---or move the attachment clips to the side mounting location and screw into the face fram of the cabinet---(Not all dishwashers have this option--but most do)
tnhuskerfan (03-14-2013)
Old 03-14-2013, 07:11 PM   #3
Thanks oh'Mike. I will try out one of those options this weekend.
Old 03-14-2013, 07:22 PM   #4
DIY staff
The particle board gets weak from the steam from the dish washer----Whatever you use----consider spreading it around under there to waterproof the area a bit-----
Old 03-14-2013, 07:35 PM   #5
Rewards Points: 6,652
Dowl rod & marine glue also works.
Old 03-15-2013, 07:14 AM   #6
Rewards Points: 3,130
How about an old-fashioned plastic wall anchor?
Old 03-15-2013, 07:28 AM   #7
If the pressed sawdust, which the counter is composed of swells anymore, then those anchors are useless.
Splitting a laminate counter top to install a dishwasher? Joeboo25 Remodeling 14 12-03-2012 08:53 AM
Dishwasher connection and wiring, oh boy! Bigplanz Electrical 18 06-15-2011 09:52 PM
attaching countertop analogmusicman General DIY Discussions 22 08-10-2008 11:53 AM
Dishwasher for short counter depth? jennamarie Appliances 4 03-17-2008 12:33 PM
Dishwasher placement jkrodger Remodeling 2 08-03-2007 02:32 PM
