Disapearing Atic Stairs Parts - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-19-2009, 11:13 AM   #1
Disapearing Atic Stairs parts
Broke the swivel poing that allows the arm and spring to pull the door up. ( The swivel point is attached to the frame) Unfortunatly the piece is factory made and pressed. I am told you have to replace the whole staircase. There has to be an easier way. Need help finding a solution.
AJ&J is offline   Reply With Quote
Old 04-19-2009, 11:32 AM   #2
Rewards Points: 1,274
I doubt there is much of a market for replacement attic stair components, as there would be for something like garage doors. If you could find the brand I would try to contact the manufacturer directly, or, if not, find a model that matches yours in a lumberyard, jot down the manufacturer's name, and contact them. (You might have to replace both sides.)
LawnGuyLandSparky is offline   Reply With Quote
Changing from carpet stairs to wood stairs DIY_user Remodeling 16 07-29-2010 07:16 PM
Basement Stairs/ EZ Stairs mjkpainting Carpentry 8 02-24-2010 09:24 PM
Removing wall under stairs Lankston Building & Construction 3 06-10-2008 07:50 AM
Prefab or custom stairs? brokie General DIY Discussions 1 01-21-2008 07:11 PM
