Direction Of Porch Flooring - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-27-2015, 01:53 PM   #1
Rewards Points: 660
Direction of Porch Flooring
Is there a preference on the direction flooring runs on a porch floor? I like the idea of no butt ends and running the boards perpendicular to the house, but wasn't sure if there was a preferred method?
The porch is "L" shaped wrapping around 2 sides of the house.
cibula11 is offline   Reply With Quote
Old 02-27-2015, 02:25 PM   #2
Rewards Points: 1,589
It depends on your floor joist and or what you're willing to do.?
Post a picture explaining what your intentions are.
ron45 is offline   Reply With Quote
Old 02-27-2015, 02:40 PM   #3
Rob
Robpo's Avatar
Rewards Points: 738
As long as they are perpendicular to what you are attaching them to and what you are attaching them to is strong enough to hold any weight on the porch.
Robpo is online now   Reply With Quote
Old 02-27-2015, 05:53 PM   #4
Rewards Points: 660
Obviously the easiest way to frame it would be to run the joists perpendicular extending from ledger to beam... Can I still do that but double up the joists every six feet to act like a beam and then attach joists parallel to the house? Since my porch will only be 6' deep I'd like to keep the number of holes dug to a minimum...only digging where I place my posts that extend to header.
Sort of like this except my posts would extend up to a header/roof
Old 02-27-2015, 08:55 PM   #5
Rob
Robpo's Avatar
Rewards Points: 738
Attachment 124369
I don't see why not. I would use double joist hangers on the beam.
Old Yesterday, 11:35 AM   #6
Master General ReEngineer
Bondo's Avatar
Rewards Points: 2,942
Is there a preference on the direction flooring runs on a porch floor?I like the idea of no butt ends and running the boards perpendicular to the house, but wasn't sure if there was a preferred method?
Ayuh,.... That's the Old School, goin' back generations, traditional porch deckin',....
The idea is/ was, pitch is built into it to drain water, with the boards, not across 'em,...
Old Yesterday, 03:28 PM   #7
Rewards Points: 660
Originally Posted by Bondo
Ayuh,.... That's the Old School, goin' back generations, traditional porch deckin',.... The idea is/ was, pitch is built into it to drain water, with the boards, not across 'em,...
Yeah I wasn't planning on it, but I'm not sure Id like to have butt joints across all sides of my porch...I'm considering composite decking.
Old Today, 12:34 AM   #8
For pressure treated 5/4 treads the joist should be 16" on center.
For composite treads the joist should be 12" on center.
Me personally I feel the composite decking is totally misleading.
Pressure treated, aluminum, or some fairly new stuff. Check it out see what you think.
http://www.prowoodlumber.com/
Old Today, 09:29 AM   #9
Rewards Points: 660
Originally Posted by ron45
For pressure treated 5/4 treads the joist should be 16" on center. For composite treads the joist should be 12" on center. Me personally I feel the composite decking is totally misleading. Pressure treated, aluminum, or some fairly new stuff. Check it out see what you think. http://www.prowoodlumber.com/
Right. So, what are you saying is misleading...the claims that it's a near perfect product? I know it has short comings, but my concern is that this is the porch that you enter our home from. I don't want it to look like a deck on the front of my house. At least with composite it looks more refined...hidden fasteners, consistent look, less maintenance. Prowood looks okay, but no too different from ac2 pt, plus nearest dealer is an hour away. I'm all ears though.
Old Today, 12:50 PM   #10
Don't take my word for it...
Look up lawsuits against composite decking companies and the trouble with composite decking.
If you wish to make it look more traditional, then I would go with the traditional T&G material, either way there's going to be maintenance.
That's why I suggested the aluminum decking since it's almost maintenance free, and doesn't retain as much heat. Aluminum decking has come a long way and you would probably be surprised. Check out all the different decking..?
https://www.google.com/search?q=alum...g&ved=0CDYQsAQ
Some are affraid to clink on links so here's one picture.
Open porch built over basement and garage- porch rot JohnMargaret Building & Construction 7 11-06-2013 12:44 PM
Laminate Flooring Direction canadiandude Flooring 4 03-03-2012 05:19 PM
Porch has shifted on a house I am considering buying. Need advice ryanclemson Building & Construction 4 01-31-2011 09:30 PM
Open two story porch flooring blane11 Flooring 1 09-28-2009 07:26 PM
flooring direction wilderstyle General DIY Discussions 3 11-30-2008 11:35 AM
