Old 11-03-2009, 05:13 PM   #1
Default Dimpled membrane on basement interior wall
I have read and learned much here. I also see that there are several methods to inulate basements. My question is can you/or has anyoneone used dimpled membrane (Deltams or superseal) on the interior basement wall dircectly onto concrete. Then frame wall and place unfaced fiberglass between studs. This would keep moisture from touching fiberglass and allow wall to breathe. I like the rigid on walls but its expensive and this is only 60 cents a ft. Thank you
griff531 is offline   Reply With Quote
More On This Topic
Your sunroom is could be sitting empty most of the time, because it's too hot in the summer and too cold in the winter. Your sunroom can become a place for year-round enjoyment with a few easy steps. Imagine it as a haven--a place to sit and read, eat or... Read More »
Hi, I'm Jeremy Blackwell. I'm here today to help you get started on your basement remodel project. Some of the common things you want to watch for in framing, is to make sure that all of your walls are plum, level and square. This keeps everything... Read More »
This is Ben Ingham with Expert Village talking about a walk out basement. The next thing after the cinder blocks wall is to put up is to reinforce in some braces some form or fashion so you can back fill where the hole was dug out of the back hook. So... Read More »
Clean Up after a Flood
Clean Up after a Flood by Expert Village
I'm James Donnelly for Expert Village and today I am going to show you what you might need in case of a flood emergency. Do not stack sandbags around the outside walls of your house to keep flood waters out of your basement. Flood waters seeping down... Read More »
When recording vocals in a home studio, you should configure your setup as if you were choosing software or a computer workstation. You'll need to consider the acoustics and atmosphere of the space in which the vocalist works, and take precautions to... Read More »
Cutting out a concrete basement floor jeffhoward001 Building & Construction 17 05-02-2009 10:50 AM
basement floor drain problem radioiowa88 Plumbing 5 10-23-2008 12:52 AM
Sunlight for a Basement Room prglor Remodeling 1 08-31-2008 06:29 PM
Rubberized membrane along outside of sillplate on 8 foot basement deepstuff Building & Construction 14 08-05-2008 11:24 AM
To AC Basement or Not? jacko10 HVAC 0 09-20-2007 05:44 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
