Old 07-12-2006, 12:29 PM   #1
Dimensional lumber
Has anyone else been experiencing problems with lumber orders. I'm in the middle of an addition and had all the lumber delivered to the site and as we start framing the walls I've noticed the dimensions are all over the board.
2x6's ranging from 5 7/16 to 5 9/16
3x6s with the same problem
the 2x12s are the worse ranging from 11 1/8 to 11 9/16
cjolson is offline   Reply With Quote
Old 07-12-2006, 07:55 PM   #2
Dimensional lumber
Lumber is dimensiond when cut, i.e. wet. After drying, there is variation, and that variation is in direct porportion to the quality of the wood.
Tscarborough is online now   Reply With Quote
Old 07-14-2006, 08:16 AM   #3
Long-Time DIYer
Mike Swearingen's Avatar
Dimensional lumber
If you go to the lumber yard and select all of a certain size lumber from the same banded stack, it is more likely to be near the same size, since it came from the same mill, same dry kiln, etc., etc.
Otherwise, you can easily get the variations that you're getting. Moisture has a great deal to do with lumber dimensions, even after kiln drying. If you can let it sit dry inside your jobsite for a few days before using it, it might help.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 07-17-2006, 05:23 PM   #4
Dimensional lumber
is +/- 1/16" really that big of an issue?
kevin hassell is offline   Reply With Quote
Shoddy Pressure Treated Lumber? spanky77 Building & Construction 17 06-25-2011 09:09 AM
Alternative to PT Lumber for Garden Benches bscout Carpentry 12 06-08-2007 09:50 AM
Framing lumber very hard?? handyflyer Remodeling 2 04-15-2007 11:44 PM
Old barn lumber as interior paneling ish91 General Discussion 8 09-27-2006 03:51 PM
