Digging Under The Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-10-2012, 09:32 AM   #1
Rewards Points: 264
Digging under the wall
I want to dig a 6 foot section of dirt from under my (stone) basement wall, below the frost line. Then I'm going to re-fill the area that was dirt with concrete.
Any risk of the wall collapsing while I'm digging under it, or should it stand on it's own? Would it be worth the effort to pour in sections? What about holding it up with jack posts and just leaving them when I pour the wall? Like really expensive rebar?
tibberous is offline   Reply With Quote
Old 09-10-2012, 10:09 AM   #2
Rewards Points: 3,130
Why do you want to do this? Are you trying to shore up the foundation? Is the wall or basement floor cracked or sinking? If so, there is a process called "slab jacking" that is used to correct such conditions. Special equipment and techniques are used to basically inject concrete underneath a building's foundation. It is most assuredly NOT a DIY job.
Old 09-10-2012, 10:15 AM   #3
Rewards Points: 264
I'm adding a 4' x 6' in-floor hot tub.
Btw - I'm not buying a hottub, because it won't fit through the door. I'm pouring concrete, then covering it with this waterproofing **** for pools.
Old 09-10-2012, 10:19 AM   #4
Rewards Points: 264
Also, I already dug a 4 foot deep hole in my basement floor, near where this one is going to go, so water level / hydrostatic pressure should me a non-issue (plus I'm on a slope)
Old 09-10-2012, 02:09 PM   #5
Interesting. Have you thought this through?? Sounds like you have no idea what you're doing.
Old 09-10-2012, 03:18 PM   #6
GBrackins's Avatar
Rewards Points: 2,108
what is the stone foundation wall supporting? is it supporting floor joists? roof? gable end wall? stop and think about what is holding up the foundation wall right now?
it can be removed, but only after on-site evaluation by someone that knows (either an experienced designer, building or professional engineer).
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 09-10-2012, 07:31 PM   #7
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
Even if you succeed in this, do you know how much humidity this is gonna dump in your house?
I hope you have a good mold remediator on retainer.
How to face a cinder block retaining wall with stone? CarrollY Concrete, Stone & Masonry 5 09-04-2012 01:26 PM
Core filling a bowing wall, please assist silverstrike Building & Construction 12 06-16-2012 11:28 PM
Retaining wall problem FMS Landscaping & Lawn Care 6 07-04-2011 07:42 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
