05-15-2010, 11:53 PM
#1
Digging basement to add headroom space
Hi, I need some advice on how to add a few inches of head room to my basement.
We have a 100 year old, brick, 2 flat. Currently the basement is unfinished.
Before we start the remodeling of the basement we would like to add just a few inches of headroom possibly by taking out the concrete floor and digging.
We have about 84 inches from the floor to the bottom of the wood beams. So it looks like taking out the concrete and digging a total of 16 inches would be enough to add celling and insulated floor and still have 90 inches between floor and celling. (90-84=6+ 3 gravel +3 concrete +3 insulated floor+1 celling= 16 inches)
I would appreciate any advice on how to go about the digging process.
I heard that we need to leave about a foot of space undug next to the walls to avoid disturbing the foundation.
We will appreciate any advice, previous experiences, books on the subject, tutorials or any relevant info.
Thank you,
Lu
05-16-2010, 07:38 AM
#2
I would have the foundation and wall structure checked by an engineer, just for good measure.
The Following User Says Thank You to Just Bill For This Useful Post:
05-16-2010, 09:40 AM
#3
Xtreme DIY'r
Ecven a foot away can cause a problem if there is enough weight & depending upon the soil
The Following User Says Thank You to Scuba_Dave For This Useful Post:
05-16-2010, 10:33 AM
#4
Concrete & Masonry
Realize that you will have a curb inside of your basement when completed, at least 16" high by 24" deep more than likely. This can be a major pain to deal with when trying to make the basement a usable space.
Do to the amount of labor involved, the cost to extend/modify any mechanicals effected, engineering costs, etc... for the very minor gain, this is a very rare kind of prokect. Don't get me wrong, it's do-able, but most look into the cost of adding an at-grade addition on vs. the deeper basement, & the addition is a no-brainer.
Good Luck.
The Following User Says Thank You to jomama45 For This Useful Post:
05-16-2010, 11:04 AM
#5
Really doesn't sound like it's worth it to gain 6". Rule of thumb is to stay on a 45 slope from the footer, but it's dependent on soil conditions. Especially since who knows what your footer would be like in a house that old. Do you have a walk out basement to wheel out the busted concrete? Are you planning to get the work permitted and inspected? May be hard to sell if you don't.
Journal of Light construction did an article on this topic about 5-6 months ago that details the entire process (They underpinned and did the curb mentioned above).
The Following User Says Thank You to walkman For This Useful Post:
05-16-2010, 12:17 PM
#6
I'm a firm believer that hard work builds character, and with that said I'm reminding myself what my long ago deceased boss told me once on a dangerous job , and he told me that there's a solution to every problem, you just have to be smart enough and have the patience to see it through. Now for the basement job consideration........What are the room dimentions now? Do you have a water leakage problem? I'm assuming you have laid up rock walls that the mortor has long ago turned to powder like sand. This is a major project and can be very expensive, but do take into consideration that dampness can be a health issue here, and the cost of running a de-humidifier can be expensive. If you have the room, lay up a 8 inch block wall on a footer with insulation of some type behind, if you drywall use greenboard. This is not the subject but how's the plumbing overall, and does it run under the floor in your project floor?
The Following User Says Thank You to bernieb For This Useful Post:
05-17-2010, 12:06 AM
#7
Totally screwed together
There was an excellent article in the Journal of Light Construction a few months back, and they did exactly what you are wanting to do. Great writeup, illustrations and everything.
Search there for the article.
The Following User Says Thank You to xxPaulCPxx For This Useful Post:
05-17-2010, 02:07 AM
#8
thank you for all your comments and suggestions.
The addition at ground level is not an option because of space. there is no room to the left or right and the backyard is just the perfect size.
I know it sounds like a lot of work to gain only a few inches of space but If i don't do it and then add a celling and a floor that may reduce my head room even more.
yes it is a walk out basement so taking out the cement is not a real problem.
The basement is not completely underground only about 40 inches.
I made a 2 holes in the cement floor and it comes out really easy. it looks like there is only about 1 inch of cement not much gravel and the dirt looks like clay.
needless to say the cement floor is very uneven and full of cracks s it looks like i will have to take it out any way.
yes I am planning to get permits for all the work.
the main idea of this project is to make the first floor apartment into a duplex. Each of the two apartments is about 1300 sq feet, remodeling the basement will almost double the size of the first floor apartment.
I am planning to make two bedrooms one bathroom and one large family room in the finished basement.
thank you for the information about the article I will look for it in the library.
I like bernieb's bosses philosophy, i kind of live by it.
I don't have a water leakage problem. Only a little moisture that comes in from the cracks in the cement floor. Not really a moisture problem either.
The plumbing is great because we changed every single pipe in the house last summer before we moved in. We changed every pipe except the underground pipes that, you guessed it, run under the basement floor. I could take the opportunity and replace those pipes as well or at least the portion that is under the house. that would be beneficial because we have extremely tall trees and their roots get inside the main drainage.
the house walls are made out of a double layer brick above ground. Underground (the 40 inches that I can see) is like you said beautiful stone. I don't know how deep the stone goes but for those 40" of stone in the basement the mortar still is ok.
A contractor told me that to hire someone to do this project will cost me about 30,000 mostly in labor. I think I can save that money by doing it myself with the help of some friends.
My main concerns are to do it safely and do it right. To get rid of the cement I can get a dumpster that's no problem. The dirt on the other hand can't go in the dumpster so I will need to do some creative landscaping in the front of the house with all that dirt. About 1200 cubic feet of dirt. Some people pay a lot of money to get dirt for landscaping, for me that will be free.
I think getting the supervision of a structural engineer is a must, so I need to look for one.
I am planning to get some insulation around the every wall but haven't looked into that.
It looks like a lot of work but I don't mind as long as is manageable and as long as i know what i am doing.
Neither my wife, my daughter nor I are very tall so I could get away without digging but if i have to take the cement out any way then why not take an extra step to make sure: 1) that i have a tall basement. 2) that i have 2 or 3 inches of gravel that will help control the moist and the radon. 3) that i have enough space for a nice celling 4) that i have enough space for a nice insulated floor. 5) installation of sum-pump and drainage system. 6) free dirt for landscaping ( just kidding)
Thank you again for all your replies, hope to hear from you soon
Lu
05-17-2010, 03:13 AM
#9
Sorry, I admit that I just scanned the posts. What about the footers under the basement walls? Will you be getting below them? That would be real ugly. On the "lip" around the perimeter, just shelve it all the way around and you've got it schnockered. 1200 cubic feet of dirt is only 4 to 4.5 truck loads; can you sell it, if need be? Have people come and dig it for free, and save you some digging?? Just thoughts. Good luck. j
05-17-2010, 03:30 AM
#10
You are going in the right direction... to say you are only adding 6" of room only proves the poster didn't read what you were REALLY doing. BTW, you may need to dig lower, I think 4" slab is standard.
Here is the article I was takling about (you have to pay for it, but it is worth it):
Lowering a Basement Floor
Gaining an extra foot of headroom isn’t easy, but it can yield valuable living space.
by John Sylvestre (5 Pages)
First 100 Words:
Lowering a Basement Floor Gaining an extra foot of headroom isn’t easy, but it can yield valuable living space John Sylvestre Lowering a basement floor is as difficult as it sounds. First you have to figure out how to support the existing house. Then — after all the finishes have been removed and all the mechanical systems disconnected — comes the fun part: breaking up the slab, excavating dozens of yards of dirt by hand, and underpinning the existing footings. But for clients with a small lot and limited space to expand, it’s sometimes the most practical way to add
View PDF | View HTML
05-17-2010, 01:06 PM
#11
Not to give you something else to "worry about" but I would do a test dig where your main plumbing enters under the concrete floor and see that the lateral pipe is deep enough for the new height. When your house was built a hundred years ago the plumbing code was different than today, and I have seen underground plumbing using "orange burg" clay like pipe 6" diameter "last forever" go house to house then after 3 or four houses go to the main sewer in the street. I doubt if you have a footer under the rock foundation ,but again dig a test ditch. I'd forget about hiring a structural engineer as long as you don't have running mud. Once your confident that the house won't cave in (haha) and I don't think it will ,you can dig down your 16 inches flush with the rock wall, and if a roto-tiller works use it. Once you have your depth you can use the concrete board half inch thick that Low's or Home Depot has to slap up against the exposed dirt wall under the rock wall ,then using 2x4's frame in for a footer of mixed concrete that will jam the base of the concrete board in. Put a small belly in footer next to rock wall, to carry away any water to a designated area to be pumped out if need to be. You can use light weight 4x8x16 core block ,2 rows high to get above dirt wall if there is one that is. You can overhang you studded wall when you build it ,stripping in for the block area. Figure your footer so you have a concrete slab rest for the floor.
05-17-2010, 02:39 PM
#12
Yea, but if OP has no where to build an addition, he really doesn't have any other options.
He already states that its 84" from concrete floor to bottom of floor joists over head. That's 7'. Building codes for habitable space require 7' from floor to ceiling. So technically, he doesn't even have enough space to add drywall for a ceiling and laminated floor directly to the concrete for a floor and stay within code.
05-18-2010, 06:57 PM
#13
Concrete & Masonry
Seriously, I hope this post was meant to be sarcastic. If not, I certainly wouldn't suggest the OP follow anything highlighted in red especially.
I've yet to meet a 4", freestanding CMU wall that I couldn't defeat with my size 12 boot........
05-18-2010, 07:10 PM
#14
Extending a home by digging out a new basement has become quite popular here, especially in London where building space for extensions is really limited and land really expensive. Paying 40 grand for a basement can add 100 grand to the value of your home there.
Most jobs can be done, depending on whether it's cost effective.
05-18-2010, 07:32 PM
#15
Xtreme DIY'r
I'd never dig down flush with the existing wall...and use a ROTO-tiller ???
Excellent way to cave the house in....vibration will cave it in much faster
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
