Different Options For Soundproofing A Finished Basement Apartment - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-09-2010, 03:25 AM   #1
Hi all,
I just bought a 40 yr old semi that has original hardwood flooring with a finished basement. My brother in law will be moving into the basement apt and the sound from the tv directly above is horrible (as well as the footsteps) I was hoping to get some input on different ideas:
1) I demo the old basement ceiling and install special soundproof insulation & drywall and screw in the joists/beams and then hire a drywall prof. to finish the ceiling
2) Install a 2nd basement ceiling with a drop ceiling with S.P. insulation
3) Install new flooring in the room above, add a S.P. vinyl, foam, patted sheet after screwing down the floor
What the approx cost for 1 & 2??
Also, what can be done about the vents, is there a special padding or spray that softens the noise coming through? I did not want to move the existing ducts...
Thanks all
- Mike
2 threads on same issue merged
Moderator
mz04zf is offline   Reply With Quote
Old 09-09-2010, 10:17 AM   #2
Soundproofing Guy
Rewards Points: 158
This is a common issue. The lack of carpet and pad makes this scenario even worse.
You can address the issue from the floor side, or the ceiling side or both. Ideally you would address the sound vibration right at the source (the floor). If you have open joists, this is a luxury.
Have a look at the diagrams in this article for ideas:
http://www.soundproofingcompany.com/...fing_ceilings/
Here's a very thorough approach from that article:
Ted White is offline   Reply With Quote
Old 09-09-2010, 10:18 AM   #3
Soundproofing Guy
Rewards Points: 158
See my reply on your other thread: http://www.diychatroom.com/f19/sound...-floors-80920/
Finished Basement Insulation cdhen14 Building & Construction 0 06-03-2010 05:43 AM
Moving ductwork to accomodate finished basement Badfish740 HVAC 1 01-13-2010 03:11 PM
Need to expand hot air heat to second floor and basement what are my options rossl56 HVAC 4 01-19-2009 04:53 AM
Basement Floor options NashvilleKat Flooring 11 04-19-2008 10:45 AM
Finished Basement Remodel Questions bioguy Remodeling 6 11-15-2007 09:56 PM
