Difference Between Door Manufacturers - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-18-2008, 07:38 PM   #1
Difference between door manufacturers
Hello all,
Thanks in advance for any advice. I am in the process of a complete renovation and I am replacing all 15 doors in the house. The bedroom doors and the bathroom doors will all be molded solid core while the closets will be hollow core. I have a bid from 84 Lumber for Jeld-Wen doors and a bid from Home Depot for Masonite doors, both the same style with the same features (it seems). They are about the same price too (Masonite is a bit more expensive). Is there a difference between the two manufacturers or a noticeable difference in quality between the two? I would rather find out now than later when there is a problem.
Thanks again.
Dcislander is offline   Reply With Quote
Old 02-19-2008, 09:27 PM   #2
remodeling pro
Check what they use for the perimeter blocking. I believe Masonite brand uses masonite for the perimeter core, thus you are fastening the hinge screws into glorified cardboard. I believe Jeld-Wen uses wood perimeter, but not positive that is still true. That is the main difference I see in the quality of these doors. Our mill supplier buys from a couple of manufacturers, so some orders come out with the masonite edges and some orders with the wood edging, but I don't know for sure from whom. Other than that, they are pretty much the same IMO. I don't think it is true any longer, but a few years back, the Masonite Corp manufactured all of the face skins, no matter who made the door. I believe by now the original patent protection has run out, and there are several companies stamping the "panel" skins.
troubleseeker is offline   Reply With Quote
Old 02-19-2008, 09:51 PM   #3
Great suggestions. I will be calling both manufacturers tomorrow. One review of the Safe N Sound by Masonite says that it is filled with a wheat grass. They say it is much lighter than solid MDF while retaining a solid feel.
Thanks for the 411.
Old 02-20-2008, 03:23 AM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Originally Posted by Dcislander View Post
Thanks for the 411.
Word ...
- Build Well -
Old 02-20-2008, 10:17 AM   #5
Talked to both Masonite and Jeld-Wen this AM. Masonite fills their Safe N Sound doors with wheat fibers to "go green" and keep the weight down while getting the benefits of a solid feel. JW uses a particle board core.
The all MDF doors really boost the cost, so I will probably go with one of these two.
Anyone on the forum have a preference? Wheat grass or particle board?
Thanks all!
Difference in S-W paints ??? Portersold Painting 13 10-04-2007 04:00 PM
difference b/ween L (blue - expensive) and M (red - cheap) copper pipes amakarevic Plumbing 4 07-31-2007 05:28 PM
208v, 230v, 240v Whats the difference? BJinaTJ Electrical 7 12-19-2006 08:56 PM
Is a big price difference normal? chevyguy1973 Roofing/Siding 5 02-08-2006 10:06 PM
