Old 03-11-2006, 12:08 PM   #1
Didn't use green treat...now what?
We just started finishing out basement ourselves, we put up a few walls and figured that we better get a permit before we get much farther. We just got the guide lines in the mail and it says that we need to use green treat for the bottom plates.
Our bottom plates are not treated. The are liquid nailed and nailed in, with that walls installed on top of them.
What is our next step. No permit or is there something else we can do at this point to bring it up to code?
tosuwyja is offline   Reply With Quote
Old 03-11-2006, 03:27 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
Pressure-treated wood means pressure-treated, and there is no after-market treatment that will match it.
Unfortunately, you may be required to rip it out and do it right from the basement floor up, or you may have wall structural problems later.
Your local Building Inspector will make the call.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 03-11-2006, 03:52 PM   #3
Carpenter
DecksEtc's Avatar
Did you happen to put plastic under the wood? If you did, you may be okay with your building department.
However, like Mike said, you may be stuck ripping it all out.
Terry
DecksEtc is offline   Reply With Quote
Old 03-27-2006, 09:37 PM   #4
Star Member
A lil' blue and yellow food color might work.
Lefty Lucy is offline   Reply With Quote
Because Green Matters EZ Rider Off Topic 1 02-16-2007 01:04 AM
Green board/ good or no? fqp25 Building & Construction 7 09-06-2006 07:37 PM
Is it normal to see green stuff on the supply pipes KUIPORNG Plumbing 2 06-30-2006 12:21 PM
Copper Hot Water Tank - Green Stain grover432 Plumbing 2 11-29-2005 12:05 AM
Old green paint marlenecapps@cox.net Painting 1 10-16-2005 08:09 AM
