Diana .confused Homeowner - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-19-2010, 04:12 PM   #1
Diana .confused homeowner
How do you make an aggregate patio over an old cracked cement one?
Mermaid 1943 is offline   Reply With Quote
Old 09-19-2010, 05:50 PM   #2
jlhaslip's Avatar
Rewards Points: 2,872
If you have the height available, you can pour over top, however, please understand that this may not be a good choice.
The old concrete cracked for a reason.
Most common issue is an improperly compacted base.
My suggestion would be to remove the old, prep the base and re-pour with an exposed aggregate mix.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 09-19-2010, 09:33 PM   #3
remodeling pro
My two cents worth agrees. New concrete over the old will end up with cracks in the same places.
troubleseeker is offline   Reply With Quote
Can a homeowner perform electrical work in MA? dpd512 Electrical 77 04-11-2012 06:48 AM
Alaskan homeowner working on home Thurman General DIY Discussions 10 08-15-2009 12:51 AM
new homeowner, inspection/electrical issues bobblehead Electrical 2 01-15-2009 06:20 AM
new homeowner, electrical questions bobblehead Electrical 3 01-14-2009 08:46 PM
Laser Level - Eyewear Required? mfleming Safety 19 01-05-2009 10:09 PM
