Diagonal Members In A Lone Load Bearing Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-16-2010, 08:07 AM   #1
Question
Diagonal members in a lone load bearing wall
Iím remodeling my 1910 brick two flat, but in the process of opening up the kitchen to the dinning room I noticed these diagonal members in my non load bearing wall. Having some knowledge of structures so Iím wondering to my self, could this be a shear wall (put there prevent lateral loads from toppling the building). The building is only 25' wide, should I be worried about removing these pieces
ericp is offline   Reply With Quote
Old 03-16-2010, 08:12 AM   #2
Remodeling Contractor
Are they notched into the studs? This was a common way to construct walls. The outer wall is a bearing wall. Are you re moving the exterior siding? And while you have the wall open be sure to air seal and insulate the wall. Also sheet with 1/2" plywood to give you good blocking to fasten the cabinets. Glue and nail the plywood on a vertical which will now work to give the shear strength at the corner. Be sure to seal and fire block the floor/wall transition, and any wall ceiling transitions. IF you make a soffit you will have to seal both wall/ceiling transitions.
Old 03-16-2010, 12:47 PM   #3
Rewards Points: 502
don't worry. that steep angled 2x4 isn't the only thing keeping your whole block from going dominos during the next strong breeze
forresth is offline   Reply With Quote
Old 03-16-2010, 05:31 PM   #4
Rewards Points: 582
There are some walls with diagonal braces known as trussed partitions which require no support from below, and can even hold up the floor beneath them. These were often used over the top of a ballroom where there were no supporting walls.
Fortunately yours is not one of these.
Diagonal members in a lone load bearing wall-fig-217-trussed-partition-spanning-space-between-two-brick.jpg
stuart45 is offline   Reply With Quote
Tags
construction
how to-create doorway in load bearing wall Nikkil Building & Construction 4 05-13-2011 11:31 PM
How to determine if it's a load bearing wall? tripower Building & Construction 8 12-30-2008 09:42 PM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 01:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
Load Bearing Wall rpatterson Building & Construction 2 10-29-2005 07:43 AM
