Old 03-15-2009, 04:22 PM   #1
Deteriorating brick walls
I have just recently purchase a row home that is over 100 years old. The U&O inspection requires states that the Basement walls are deteriorating and require parging. The basement walls are all brick and there is no sump pump. After doing some research it seems that parging the basement walls is only a temporary aesthetic remediation and in the end will result in more damage to the brick. What is the ideal and permanent solution to the "deteriorating of the brick walls"? I read that tuck-pointing, or repointing of the brick with a lime/portland type I/II mix? Any advice?
jelost is offline   Reply With Quote
Old 03-15-2009, 07:30 PM   #2
Tuckpointing then parging with a Lime mortar/plaster(they are essentially the same thing) is what you want to do. Search this forum for "tuckpointing" and "lime mortar"; the question has been answered many times.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Old 03-15-2009, 09:21 PM   #3
Hi,
Thanks I will have a look. I just wanted to make sure that if I got this professionally done, I was getting the right thing done and not just doing a cover up. If I bring a professional in, they may or may not know that it would be better to get a half lime/portland mix of mortar. On average what would it cost me to tuckpoint four 5 ft x 5ft walls ?
thx.
Sealing historic brick tenzo General Discussion 2 11-22-2008 04:04 PM
Keeping Water out of the Top of Brick Walls o2barockstar Roofing 4 02-18-2008 03:50 PM
brick foundation walls drummerjim Building & Construction 5 01-23-2008 06:23 AM
Old Brick House inside walls rick32 Building & Construction 6 11-08-2007 07:49 PM
Nailing / drilling into adobe and brick walls Gringa General Discussion 1 03-30-2006 08:50 PM
