Detatched 16x20 Deck On Piles - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-01-2012, 08:29 PM   #1
detatched 16x20 deck on piles
so i have this deck to build. its 20' wide against a house and out 16'.
grade is 8 inches from the top of the deck. The ground is very tough. lots of hard rock and seems to be very sturdy. I dont want to attach it to the house (permits needed and a PITA)
heres my plan. 3 rows of 3 piles 16" deep x8inch holding a saddle. then a 2 ply 2x8 treated beam running the 20' length down each row of piles. the beam top will be flush with the grade allowing me to use 2x6 treated lumber for the joists and top it off with 5/4" deck boards. only problem is im worried about heaving but the ground is super solid (almost impossible to dig in with a shovel) and the spans between piles are near the maximum allowed here in canada so if it does heave its spread out over a longer distance.
does anyone see any problem with doing it this way?
Mattyboy89 is offline   Reply With Quote
Old 11-01-2012, 08:40 PM   #2
GBrackins's Avatar
Rewards Points: 2,108
matty,
check out the American Wood Council's "Prescriptive Residential Wood Deck Construction Guide." This is based upon the 2009 International Residential Code, basis for most local and state building codes. It should answer your questions.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 11-01-2012, 09:00 PM   #3
Civil Engineer
Rewards Points: 4,576
GBrackins has given you the link for the IRC deck building code. Of course, from your description, your deck may not be subject to code, and it sounds like you do not need a permit. This would allow you the flexibility to design based on any code you choose, or to custom design the deck based on fundamental engineering principles, or to just wing it and build it any way you choose. It is impossible to evaluate whether your plan is OK unless you tell us what your design basis is going to be. If you want to build to IRC code even though that is not mandatory, then you really need to start by reading through the code, as it discusses in considerable detail essentially every aspect of deck construction.
Daniel Holzman is online now   Reply With Quote
Old 11-01-2012, 09:12 PM   #4
Ok. I have the Canadian building code and the spans and everything meets code its just the code says that if the deck is stretched to the house then it needs piles as deep as the footing (if within 5 feet from the house) ill take a look at the link and see if it sends me in the right direction
Old 11-01-2012, 09:16 PM   #5
GBrackins's Avatar
yes if you have piles within 5' of the house then the pile must extend to the same depth as the footing of the dwelling. this is because all footings (and piles) must bear upon undisturbed natural material. when digging for a foundation the excavation is always more than the size of the dwelling. typically within 5' of the dwelling the soil has been disturbed, thus the reason for going deeper. make sense?
Gary
Old 11-01-2012, 10:52 PM   #6
i was trying to steer away from that since it is not attached to the house. i figured that if you can float a deck on deck blocks then the small pile is essentially the same thing its just buried 2' deep. i cant get a bobcat in the backyard to drill through the hard rock and dirt so the piles that deep are not really an option for me. the house is a basement entry built into a hill and the deck is off the dining room which is on the second floor
Old 11-01-2012, 11:19 PM   #7
GBrackins's Avatar
where are you located? do you know what your frost depth is?
Gary
Old 11-01-2012, 11:44 PM   #8
in british columbia. its about 36 inches
Old 11-02-2012, 12:24 AM   #9
GBrackins's Avatar
I'm not up on the National Building Code (Canadian). Reason you should have your location listed in your profile.
in the states if you build a free standing deck that is not supported by the dwelling you are not required to have footings (depth) below the frost line (except the must bear upon undisturbed natural material or engineered fill).
With that said, the piles must be capable of supporting the load they impose on the ground. if the soil has been disturbed and not properly compacted they can sink. unequal sinking will cause members to twist. not a good thing.
if you are required to have a permit to construct then you must follow whatever the code requirements are in your jurisdiction. if you are not required to pull a permit then you can do pretty much whatever you want, of course realizing it may lead to problems.
if building a ground level deck you may consider a patio. if elevated deck you should install lateral bracing as shown figure 21 on page 14. this prevents the racking of the deck. with a free standing deck it should be done on all corners, as well as intermediate posts along the perimeter.
make sense?
Good luck!
Gary
Old 11-03-2012, 09:51 AM   #10
Rewards Points: 224
interesting. as i am going to build a deck myself, hopefully next summer.
i also am going to do a floating deck. i was planning on cantilevering it over to the house. perhaps this will work for the OP ? how far is a safe overhang ?
Fix'n it is offline   Reply With Quote
Old 11-03-2012, 09:53 AM   #11
Rewards Points: 224
oh. what is "racking" ?
Old 11-03-2012, 10:01 AM   #12
Rewards Points: 13,300
Swaying, moving from side to side.
Old 11-03-2012, 11:22 AM   #13
Framing Contractor
Does that mean that you don't need permits if you don't attach it to the house?
Joe Carola
Joe Carola is offline   Reply With Quote
Old 11-03-2012, 11:54 AM   #14
GBrackins's Avatar
check out the "Prescriptive Residential Wood Deck Construction Guide." it will give you pretty much all the information you need.
Gary
The Following User Says Thank You to GBrackins For This Useful Post:
Fix'n it (11-04-2012)
Old 11-03-2012, 12:07 PM   #15
It depends on your region and town whether you need a permit for a non attached deck or not
Deck Staining Nightmare steven994 Painting 6 04-06-2014 10:10 PM
foundation walls to support a deck bubbler Building & Construction 1 04-12-2012 04:27 PM
Pergola over existing deck cpfullback Building & Construction 0 08-04-2011 12:36 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 12:17 PM
