Old 02-27-2004, 09:35 PM   #1
Unregistered
Guest
Posts: n/a
Detached Garage Insulation
What would be the correct way to insulate the roof deck of a detached garage. The garage is heated and will be air conditioned. The ceiling will not be sheetrocked.
Old 02-28-2004, 12:56 PM   #2
You can put 1x3 purlin on the underside of the ceiling joists and lay in batt insulation and then blow in loose insulation over that.
hatchet is offline   Reply With Quote
Old 02-28-2004, 04:31 PM   #3
Grumpy's Avatar
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
My advice would be to folow Hatchet's advice unless you wants to use the "Attic" space for storage... which I think you do because you said roof deck.
Hmmm most garage roofs are hip style. This makes it tricky. I could draw a sketch but can't really explain it in words.
-Grumpy
Sometimes the savings that comes from doing it yourself can be blown away with one mistake.
The information found in this post is not to be considered legal advice. All information should be considered relative, not specific. Never attempt any repairs you are not comfortable with. Always maintain safety! The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
detached garage Kapt Electrical 12 01-17-2007 09:37 AM
Framing a carport on a detached garage nomagic Carpentry 3 05-04-2006 11:43 PM
Best way to insulating a heated detached cement block garage Joe Nulph Building & Construction 1 03-06-2006 11:30 AM
Detached garage adding a 3 way switch. Slatherd Electrical 4 01-02-2006 03:53 PM
