Detached Gable Structure For Backyard Shade - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-26-2013, 11:58 AM   #1
Rewards Points: 242
Detached gable structure for backyard shade
SUbmitted plans to local building department for building a detached gable roof over part of my backyard patio. We do not want to cut into the patio to place a post so an engineered LVL beam is the choice to be able to span 22 feet. The structure is going to be 22ft x 18 ft.
See photos for orientation and drawings.
collegetry is offline   Reply With Quote
Old 09-26-2013, 01:59 PM   #2
Rewards Points: 13,300
I'd have at least 3 issues with that design.
You have the roof pitched so 1/2 the waters going to be dumping on the high side of the patio.
Why would you have the grill outside of the roof line?
LVL's will need to be covered.
Old 09-26-2013, 02:02 PM   #3
Rewards Points: 242
Will be using gutters to direct water.
We have our reason for not covering entire patio.
You are correct that the LVLs will need to be covered.
Wood shade structure beam requirements CuriousHomeowne Building & Construction 9 04-15-2012 06:32 PM
Ventilation - Opposing gable, limited soffit + box vents = Screwed up? darlingm Roofing/Siding 1 09-07-2011 11:13 AM
86 the Gable Vent??? 11thHourZero Roofing/Siding 5 07-17-2011 08:09 PM
Shade Sail structure lemuzz Building & Construction 4 01-22-2009 07:47 PM
Subpanel - detached structure former33t Electrical 9 03-13-2008 10:49 PM
