Depth Of Crushed Asphalt - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-25-2007, 05:48 PM   #1
Rewards Points: 790
Depth of Crushed Asphalt
I am adding crushed (reclaimed) asphalt to our driveway. There is already a solid and compacted base of gravel. Our driveway is connected to an alley which used crushed asphalt. I was curious how deep I should lay the crushed asphalt? Obviously this will be needed to determine the total amount.
cibula11 is offline   Reply With Quote
Old 09-26-2007, 11:46 AM   #2
not much if you already have a good base down......... Crushed Apshalt is the is one of the better base matl's you can get ..............
mdlbldrmatt135 is offline   Reply With Quote
Old 09-26-2007, 11:48 AM   #3
Rewards Points: 790
Would 2 inches be too deep? Or should I just put down an inch or so?
Old 09-26-2007, 11:49 AM   #4
I don;t think you'd need more than 2" (compacted)
Old 09-26-2007, 12:24 PM   #5
Rewards Points: 790
Thanks,
That's what I thought too.
Elastomeric coating for asphalt shingles? Arndavis Roofing/Siding 1 09-04-2007 10:42 PM
driveway, concrete or asphalt? johnny331 Building & Construction 2 06-19-2007 10:03 PM
Depth probe tool amakarevic Building & Construction 5 06-19-2007 03:30 PM
paint textured with crushed stone. ouchmythumb Painting 5 05-12-2007 07:45 AM
