Old 10-30-2009, 04:35 PM   #1
Default densguard not flush with tub flange
I called densguard and they told me to install the densguard above the tub flange. I installed it this way but now I realize that this may have created a problem. The 1/2 inch densguard hangs over the flange. It is not flush with it. So if moisture runs down the denguard, I suppose it can wick around the bottom and the gypsum can soak it up. I included a really bad picture. I caulked between the back of the densguard and the tub flange. Should I caulk the whole bottom of the densguard.
Bigguy0 is offline   Reply With Quote
More On This Topic
Hi this is Jon on behalf of Expert Village in this video clip I will be talking about caulking the seams. Now that we have replace all of our new siding on our house and we have securely attach it we need to go through and put caulking on all of the... Read More »
Hi my name is Nate McCullough on behalf of Expert Village. In the following clips we're going to talk about the proper way to repack, grease, and adjust your vehicle's wheel bearings. In this clip we're going to talk about the proper way to seat your... Read More »
When you’re caulking around a tub or a sink, it’s important to dig out the old caulk first, especially if it’s grown some mold, because that will just go through the new caulk. So, it’s a little bit tedious, but it really is... Read More »
Removing a Toilet
Removing a Toilet by Expert Village
Now, before we pull a toilet, we've emptied the tank for the water. That was easy, but we need to empty the bowl of the water. So what we'll do is we'll pour a bucket of water; half a bucket of water in the toilet, and we'll pull it kind of fast, and the... Read More »
All right, so we notice that the wax ring is a little low on this side, so when we reset the toilet we're going to keep an eye out to make sure that that has the proper amount of wax on there. We want to remove all the excess wax; make sure we don't get... Read More »
Flange extender over lead waste pipe Millrun Plumbing 0 10-22-2009 11:03 PM
Tiling around tub with very wide flange petsparkle Kitchen & Bath Remodeling 3 04-20-2009 05:53 PM
Toilet flange arrangement with new floor bvsmitty Plumbing 2 01-16-2009 07:51 PM
Closet flange: flush with finished floor, on on top of? rjhaleymd Plumbing 4 11-20-2008 08:43 PM
Flange Help Needed tajones44 Plumbing 2 07-11-2005 06:42 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
