Demolition Of A Cistern - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-04-2009, 05:14 PM   #1
Demolition of a cistern
Has anyone demo-ed and filled in a cistern? I have one in my backyard that has been capped with cement. What did you fill it with? And why do it? Thanks.
Trish99 is offline   Reply With Quote
Old 04-04-2009, 07:12 PM   #2
joed's Avatar
Rewards Points: 13,718
You do it because it is often required by law when abandoned. You don't want anyone falling by accident if the lid gives way.
Normally you fill them stone, sand or clean fill.
Old 04-04-2009, 08:25 PM   #3
In this area code requires gravel and sand except the top 4 feet, there you can use soil.
hayewe farm is offline   Reply With Quote
Old 04-04-2009, 09:01 PM   #4
Code Requirements for demo of a cistern
According to the code here I don't have to do anything to it because it is capped in cement. So I don't know how deep it is and can't really know without opening it up and then I'll have to reseal it according to code and the township will have to get involved. I plan to put a deck over it eventually so I if I do that sooner rather than later I guess I could save some money and time by doing nothing. So, assuming that safety and code requirements are not an issue, can you think of any reasons to get rid of it?
Old 04-04-2009, 09:51 PM   #5
joed's Avatar
It doesn't look to be in very good shape. The part above ground appears to be crumbling now.
Old 04-05-2009, 01:06 PM   #6
Mold!! Let's kill it!
Rewards Points: 2,012
It could make a great place to run your rain water from the downspouts.
Old 04-05-2009, 01:45 PM   #7
Rewards Points: 780
You say you're covering it with a deck? It's possible that one or more of the posts will need to be cemented into the ground right where the cistern is now.
I guess I would fill it in anyway, just to know that no kids or pets would ever fall in and drown, especially if a section of it caved in and left a small hole in your yard big enough for them to fit through.
A cement cover gives you no gaurantees as cement cracks and breaks quite easily. Not to mention if the ground supporting the cement lid collapses.
On the farm I grew up on, we had a cistern cave in as my brother was driving a tractor over the edge of it. It was pretty deep and had water in it still. We never knew it was there until it caved in. We found another one too, a couple years ago under the kitchen floor when we gutted the same house and pulled up all the floor boards.
gma2rjc is offline   Reply With Quote
Old 04-06-2009, 12:59 AM   #8
Thanks guys. I plan to pop the top drop a tape measure in to see how deep it is. With a lot of luck it isn't that deep and it won't take much to fill. It is crumbling some so I don't think it'll be much to demo the above ground part.
Tags
cistern well
Cistern to use seasonal creek to irrigate lawn Jeff in Poway Landscaping & Lawn Care 2 07-30-2008 03:00 PM
Toilet cistern problem pmasalawala@talk21.com Plumbing 5 08-07-2007 03:38 PM
Ceiling demolition chathamsq Building & Construction 6 01-30-2007 11:22 PM
Toilet; Cistern to Toilet pipe ( Complete Novice) broke1973 Plumbing 1 07-15-2005 08:34 AM
